Old 01-16-2007, 11:49 AM
sLADe781 sLADe781 is offline
Car won't start... ;o(*
Okay guys, my car wouldn't start this morning when I was trying to go to work. When I turn the key, it would start turning but it seemed to not have enough "juice" to actually start. Not sure if it's a battery or starter issue. Anyways, it smelled really bad also. Kinda like a mixture between gas and oil burning.
For those who have been here awhile, it sounded similar to last year when I thought my timing belt broke and all the rattling started occuring afterwards. I still haven't figured out what the rattling noise is but maybe it's related!?! I did take the car to a shop and when they first initially looked at it, they said it was my water pump going bad and I had to change it. I bought the whole timing belt kit from Rockville but when I brought it back to the shop to have the service done, they pulled off the belt cover and was like "wow, your belt and water pump looks brand new." So then they say it's probably some pulley down there but said I should wait before I changed the belt and everything else since everything looked new.
So yeah, any thoughts from the experts here? I'll see what else I could find out once I get home tonight but I won't have a lot of because I have class tonight. This sucks...school starts and my car screws up on me....my typical luck...
Thanks in advance.
-Oh yeah, I also didn't start my car the whole day Monday and it was super cold this morning too.
Old 01-16-2007, 12:20 PM
liquidPunk's Avatar
liquidPunk liquidPunk is offline
Send a message via AIM to liquidPunk
Re: Car won't start... ;o(*
I would say its prob. just the battery dude, did you try to jump it? how old is the battery?
hmm, it seems like the rattling would be easy to figure out just by looking for something that is vibrating, especially if they say its a pulley. but im no mech.
1992 Mitsu 3000gt sl 5sp
- High flow filter - Pioneer head, dual 10's - H4 headlight conversion
- Throttle Body Spacer - The "For God's sake stop that infernal buzzing" mod
- LED "Snake Eyes" - Lightweight Crank Pulley
-More to come-
Your 3000GT is the 5095th out of 6964 . Only 41exactly identical
Bloody Knuckles from Changing Fuel Filter Crew Member #1
Old 01-16-2007, 12:55 PM
Igovert500's Avatar
blue + red light magnet
Yeah try to jump it with something larger than a 4banger. I generally always try and find a truck for a jump. Or AAA has those jumper boxes. Anyway, take hte battery to Autozone and have them check it out. If that checks out we can eliminate it from the list.
The smell of gas isn't good. Did you pop the hood when htis happened and check for any visible gas leaks? Also take off the oil cap, and smell inside. Smell gas? If hte engine flooded, the gas can leak past teh rings and contaminate the oil. If it did, you wanna dump your oil and filter and replace. New oil is cheaper than a spun bearing.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 01-16-2007, 12:56 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
as Liquid suggested, test the battery first. if you can jump start it, drive to AutoZone or a local chain store and have them test the battery (most chains should offer this service for free). while you're at that auto parts store, pick their brains about what else it might be.
as for the rattling, i ran across something that might be related. a local guy's 3S here in Dallas had an awful rattling sound. turns out it was his AC pulley. there are 6 bolts that hold the pulley on, and for some reason, a handful of 3S are plagued with the problem of the pulley vibrating so much that some or all of these 6 bolts come loose or even shear off! for the 3S cars that have this problem, replacing the pulley, putting in newer stronger bolts with threadlocker, none of these remedies fixes the problem for good; it always vibrates again and brakes the bolts.
so what i did for this guy's car was to get a shorter belt (NAPA part #406-0408) that bypassed the AC compressor and install it. instead of wrapping around the 5 pulleys on that side of the engine, it just wraps around 3: crank, alternator, and upper idler pulley. it may seem trick to get on, but the way to do it is to put it around the alternator and upper idler, then put it on the top part of the crank. as you rotate the crank clockwise, it will pull the belt on. here is the thread i found this stuff in http://www.3si.org/forum/showthread....ht=delete+belt.
so that's just an idea what the rattling could be. but definitely get your car started, then try to figure out what the rattling could be. a way to trouble shoot is to remove the ac/alternator belt, then start the car (don't worry, it will run fine for a minute or so), and if the rattling stops, then you know its a pulley on that belt that was rattling.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 01-16-2007, 02:45 PM
Well, the rattling is still the start-up rattling that I've been complaining about the past year or so. It only rattles when I start my car up when the engine is cool. If I drive it for about 20 minutes or so, the car won't rattle when I start-up the car until it cools down again. Yeah, I still need to try and get an audio of that again... But I'll try taking off the AC belt during startup.
As far as the battery goes, I did check it before when my IAC went bad and everything checked out. During that time though, the car was still rattling of course. But yeah, if I can't get it started when I get home I'll try jumping it with my dad's 4Runner.
Thanks for all the replies guys.
Old 01-16-2007, 03:14 PM
liquidPunk's Avatar
[quote=Igovert500]Yeah try to jump it with something larger than a 4banger. quote]
You have no idea how many people try to do that! LMAO, and they only let it sit for five sec. on top of that, then its "OMG the starter!" lol
-More to come-
Old 01-16-2007, 06:46 PM
Okay, so here's what I got. Car won't start even with a jump. I don't have time tonight to take the battery to AutoZone but I don't think it's the battery.
My dad kinda thinks fuel isn't getting through or something. Reason being is that it seems to be turning but just isn't "catching" to start up. Do you guys think it could possibly be the fuel pump?
I have a video so I'll post it before I leave for class tonight if I can. I tried sticking the camera as close to the engine as possible so hopefully the sounds quality is a bit better.
Thanks again guys.
Old 01-16-2007, 06:52 PM
Linebckr49's Avatar
could be fuel or spark. too early to tell. take the battery from ur dad's car and put it in ur car. then try to start it.
93 3000GT base
Old 01-16-2007, 06:55 PM
^^What's the difference between that and jumping? Just more voltage since it's not being transferred through cables?
Old 01-16-2007, 07:06 PM
VR43000GT's Avatar
VR43000GT VR43000GT is offline
Send a message via AIM to VR43000GT
You could check to see if the fuel is getting to the fuel rail at least with about 5 minutes of your time. Just disconnect the "w" shaped connector on the right side of the motor (when you are looking at it) by simpily taking off the two bolts and throwing a good sized paper towel under it and then turn the ignition for just a sec and see if any gas comes out. If everything is working properly (minus the injectors) it should shoot out like water out of a garder hose. Like I said do not turn it over for too long though unless you want to clean up gas all over the motor.
Old 01-16-2007, 07:20 PM
Videos:
and
The sound's still super crappy but hopefully it'll give you guys the general idea of what's going on. Also uh...ignore the animals...my dad recorded over his hunting video. LMAO I swear, no animals were injured while making these videos. LOL
SL, you got a picture of what you're talking about? Because I can't seem to locate the "w" shaped connector and it's getting dark real fast.
Thanks.
Old 01-16-2007, 07:38 PM
VR43000GT's Avatar
In this pic it is an aftermarket piece so it is not really "w" shaped but here it is.
Just take off the two bolts on each side where it mounts to the fuel rail.
Old 01-16-2007, 08:40 PM
Igovert500's Avatar
Yeah check for fuel and spark. You aren't getting one.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 01-16-2007, 10:59 PM
Linebckr49's Avatar
uhhhhhhhhh, that would tell you whether or not ur battery is bad. cmon now, use ur head.
oh, and from your videos, it definitely sounds like fuel or spark. it sounded like it was gonna catch for a second. probably one of your cylinders is flooded. get some starting fluid and spray it into the combustion chambers (either via lower intake plenum or spark plug holes).
93 3000GT base
Old 01-17-2007, 01:56 PM
Well if it was flooded and I wait about 8 hours or so, it should start up again, right? Once all the fluids go down!?!
If it's fuel or spark related, what do I do/change to fix it? New plugs/plug wires? Would it be really time consuming? Because I probably might have to take this one to a shop because I really don't have any time on my hands because of school. Hopefully it's not a super complicated job...
