Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 01-16-2007, 11:06 AM
fenwaynomar fenwaynomar is offline
how to change a head unit
How do i change the headunit of my 97 saturn sl? i really just need to know how to get the stock headunit out because i couldnt figure it out... i dont think i have to take off the whole dash. thanks a lot for ur help
Old 02-04-2007, 08:05 PM
holdemjunkie holdemjunkie is offline
Banned
Re: how to change a head unit
u dont have to take the whole dash off , it's fairly simple, there should be 2 plastic push screws on each side of the cover around the radio , it houses the rear defog switch. After removing those, it is prob held in by some clips, just pull on them gentley and they should pop out.When u get it loose you will have to remove the elctrical connection to the rear defog switch. After that you should be able to remove the unit by removing a coulple 7mm screws
Old 02-04-2007, 10:10 PM
PlayStation3 PlayStation3 is offline
oh i cleaned that up. you don;t need to discount the harnesses
now i would recommend a waring harness it took me like 2 mins to change out my HU including taking the center console apart.
