Old 01-16-2007, 09:21 AM
sawdust2 sawdust2 is offline
Question Transmission Filter or Flush
My Grand Prix GT with a 3.8 motor, has 107,000 miles. I don't know if the filter has ever been changed. Which is best, drop the pan and install a new filter and oil, or have it flushed? It shifts just fine with no problems at this time.
Old 01-16-2007, 09:45 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: Transmission Filter or Flush
With your mileage I would be careful about flushing. Just do a pan drop consisting of ATF (Dextron-III) and a screen filter. You will need around 7.5 quarts of ATF and I would stay with the AC Delco screen filter, part #TF304 (25313825). The pan gasket can be re-used. Pan bolt torque 10 ft-lbs.
Timeslip 08/12/06
AF Community Guidelines
Old 01-16-2007, 11:45 AM
guitarfish's Avatar
guitarfish guitarfish is offline
I do a filter/fluid change about every 30K. Takes about an hour. I've always used the Fram kit FV1129. There's a small ring-sized grommet included - I seldom replace it. Kindof a pain in the butt to remove, you have to pry it out with a screwdriver.
Old 01-16-2007, 01:30 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
I 100% agree with bnaylor on this. With any trans over 80k that has never had a trans flush, it is a BAD idea to do a flush. Only replace the filter and what fluid is in the pan when you drop it. A trans flush at your mileage will almost certainly cause major problems due to the new fluid being grippier than the old. It most often shocks the clutch friction plates, shearing them from their backing plates, necessitating a complete rebuid. Trans flushes as regular maintenance are not bad, although I feel they are totally unnecessary and a waste of money if the trans filter is serviced as it should be (every 36k to 50k depending on driving habits).
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 01-16-2007, 02:52 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Flushing has killed a lot of transmissions.
Just new filter and new fluid to fill it back up is a lot safer and better.
And no dope or additives.
MT
Old 01-17-2007, 09:35 AM
rubberman rubberman is offline
so no Seafoam TransTune? i used some on my tranny when i started getting the hard shifting/whining when i installed my aftermarket PCM. but when switching back tothe stock PCM it quit.
also when changing tranny fluid/filter, i was taught way back when to drain the fluid in the pan plus briefly go thru each gear to remove the extra fluid in each gear. So really all we need to do i refill the fluid that we dump out in the pan? any tips for pulling the pan and not spilling fluid over myself or floor? on previous vehicles, i installed a drain plug on the first tranny fluid change to make it easier next time.
2000 Grand Prix GT w/ gold package.
K&N CAI intake, U bend delete, ZZP PCM, Ractive oval exhaust tips, ZZP 3" downpipe
2004 Chevy Trailblazer EXT
Keep on Keeping on...
Old 01-17-2007, 10:18 AM
MT-2500's Avatar
AF - Advisor
Just like a flush additives can do more harm than good.
On draining get the biggest pan you can.
I use the end cut off of a 55 gallon drum.
When dropping pan go easy and drop one corner first.
Drain plug is optional. And is handy for just draining fluid.
But the pan need to come off to change filter.
Good Luck
MT
MT
