Go Back   Automotive Forums Car Chat > Chevrolet > Venture
Old 01-16-2007, 04:27 AM
03bluventure 03bluventure is offline
windshield wipers not working properly
We started the van today with remote start and the wipers were on but froze in place. so now they will only work on high and no othor speed settings and the will not go down in the off postition because when you go from high to medium they just stop where they were at. any ideas would be greatful thanks
Old 01-16-2007, 05:47 AM
ponchonutty's Avatar
ponchonutty ponchonutty is offline
Re: windshield wipers not working properly
You broke the cancel cam inside the wiper motor. Normally these break on their own. If you take a look around, you'll notice other GM vehicles with the same problem. The only fix is to replace the motor assembly.
Silverado Ext. Cab 4x4 z71
Pioneer 4900mp
Orion P6.2 Componet sets front
Orion C63 Coax rear
DirectedVideo 9" all in one DVD with surround
2007 SATURN OUTLOOK AWD XR with full entertainment package
Old 01-16-2007, 12:10 PM
some one said that it could be the switch it this likely
Old 01-16-2007, 08:59 PM
No, I doubt it but then again, it's hard for me to tell you what's broke without seeing it in person.
Pioneer 4900mp
Orion C63 Coax rear
Old 01-16-2007, 09:39 PM
LMP's Avatar
LMP LMP is offline
ponchonutty is right. THis unit is fragile..does not endure abuse...and wiper blades getting stuck in ice is abuse. I suggest you live with it during this winter. Turning the wiper OFF before leaving car is a mandatory checklist item when equipped with remote start. Sorry it turned out that way...but as poncho said...this is almost a question of "when"...rather than "if"....
you can check at rockauto.com for an idea of price...and this is an item that should be procured as new...unless you find one on a recent "totalled".
EDit: as suggsted in following posts, ground is indeed a problem with these units..had to "reground" the unit on my son's z-34 a few weeks ago..but that was a '92...yours is rather new so I do not think it is a ground probleem...and my son's had internal damage too and refuses to park regularly.
'93 Ponty Transport 3.8; 2011 SUzuki SX4 AWD (wife's) ; 2015 Sorento 2.4 AWD 1928 Graham Paige Model 629
I don't believe in miracles.
Old 01-16-2007, 09:47 PM
dr pep dr pep is offline
seen it befor cracked solder joints maybe i am wrong just my input.
Old 01-16-2007, 10:10 PM
stomana stomana is offline
Check ground on the wiper box inside vith the electronick card.it is smoll scrue on the midle of the box.The moisture (water) koming inside.After htat tape the wiper box around with aluminam tape for duct.
Good luck.............
Old 01-17-2007, 04:18 AM
thanks for all the ideas i will check it out later and let everyone know what becomes of it
Old 01-17-2007, 02:30 PM
'97ventureowner's Avatar
'97ventureowner '97ventureowner is offline
I'd like to add also that a poor design of the van also leads to this problem. There is a "pocket" where the wipers sit in the normally parked position, and in the winter snow and ice accumulates in that pocket. It is difficult at times to try and get the snow and ice out of that area to free the wipers up to work properly. I've also seen a small chunk of ice get dislodged and sit under the wiper arm, which causes the wiper to not be able to clear the windshield properly.
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people.
If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno
" A Good Thing To Know"
