Go Back   Automotive Forums Car Chat > Mercury > Cougar
Old 01-15-2007, 11:32 PM
JRG440 JRG440 is offline
99 Cougar 2.5 v6 5 speed will not crank
I have a 99 mercury cougar 2.5 v6 5 speed that will not crank up. Push in the clutch and turn the key, and nothing. Car has power, can even push start the vehicle and it runs fine. Other that the obvious, (starter, neutral saftey switch) what else can cause this? Also, where is the neutral saftey switch located on this car? I've looked and looked and can not find it.
Thanks
Old 01-16-2007, 04:43 PM
jakegday jakegday is offline
Send a message via AIM to jakegday Send a message via Yahoo to jakegday
Re: 99 Cougar 2.5 v6 5 speed will not crank
the battery?? it may be strong enough to power everything else except the starter....
2001 Grand Prix GT: cat/u-bend/resonator delete, zzp PLOG, Custom Intake, DHP PCM,
1981 Fairmont 6cyl 3 speed
1978 Ford Ranchero GT 302 with a few goodies
Old 03-07-2007, 06:17 AM
karro karro is offline
hello!
it's probably too late to respond, but, if dashboard lights don't dim, when starting the car, I would say, that battery is ok. IMHO, the next thing to check is the ignition switch.
IIf the car was hesitating to crank before that, like, you turn the key, nothing for some short time (up to a second, let's say), then off it goes, I'm almost sure, this is it. Also it might be related to wiring at the starter, loose contact or something.
hth,
karro
