Go Back   Automotive Forums .com Car Chat > Nissan > Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail
Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail Nissans greatest 4WDs and SUVs
Old 01-15-2007, 11:01 PM   #1
krisk
squealing drive belts ????? pathfinder 2003
Three new sets of belts and still squealing very loud. Sometimes after turning the wheel or even hitting thefrost switch. Most of time when the car is cold it squeals.
krisk is offline   Reply With Quote
Old 01-16-2007, 11:12 AM   #2
88pathoffroad
Send a message via ICQ to 88pathoffroad Send a message via AIM to 88pathoffroad Send a message via Yahoo to 88pathoffroad
Re: squealing drive belts ????? pathfinder 2003
So get new belts. Old belts do that before they break...
88 XE V6 4x4, 33x13.50 Swampers, 6" lift, winch, etc etc etc
Admin of NPORA, Moderator for NPM, AllNissans.com and NissanHelp.com forums
88pathoffroad is offline   Reply With Quote
Old 01-17-2007, 01:56 AM   #3
circeseye
circeseye's Avatar
um did you even read his post he said
3 new sets
lol
i have a 96 with the same problem and havent a clue what causes it. went threw all the pullies and everything and still makes a squeeking sqweeling sound
circeseye is offline   Reply With Quote
Old 01-18-2007, 09:37 PM   #4
88pathoffroad
Woops, my bad. Try removing the belts one at a time and running the engine for a short time. The one that results in no more squealing is most likely the culprit. Start troubleshooting there.
Old 04-17-2007, 02:46 PM   #5
jive1414
I've been having the same damn problem in my '01. The shop said that all my belts were shot and I needed new ones. I shelled out $170 and now my car squeals EVEN LOUDER!!! I took it back to the shop, it's there right now. I'll update you on what the mechanic says.
jive1414 is offline   Reply With Quote
Old 04-18-2007, 04:03 PM   #6
denisb
If the old belts were way overdue, it is possible that the pulley's got to be cleaned.
denisb is offline   Reply With Quote
Old 04-18-2007, 04:56 PM   #7
jive1414
Actually, it turns out that the idiot didn't set the proper tension and a belt was loose. So krisk, guess you'd want to double check that all your belts are tight.
Old 01-05-2008, 02:29 PM   #8
mr-realtor
My squeaks too and the belts are new so I will go back to the place that installed them and have them try and correct.
mr-realtor is offline   Reply With Quote
Old 03-11-2012, 06:56 PM   #9
MikePathfinder2001
I just replaced my alternator (what a pain in the but), anyway, after installing the new belt, it is squealing like crazy. If anything, I thought the belt was too tight. Anyway, how tight should I screw the Idler pully? It was on so tight, I needed extra leverage to loosen it. When I retightened it, I was conservative. It wasn't squealing before I changed the alternator, so I'm farely certain that is must be my belt. Is it a general rule of thumb that if it is squealing, that the belt is too loose?
MikePathfinder2001 is offline   Reply With Quote
Old 11-19-2013, 02:15 AM   #10
Xavier Edziwa
I have a nissan terrano (japanese). The following suddenly happened:fuel recorded full tank, odometer changed from 132... to 99999999, speedometer recording could not exceed 20km/hr, temp gauge shoots to high before the car even moves and tachometer cannot read the revs
Xavier Edziwa is offline   Reply With Quote
