Old 01-15-2007, 09:24 PM
jl856 jl856 is offline
Question Trac Control won't shut off ?
My son has a 2000 GP. When you push the button to shut the traction control off, the Trac Off light does not come on and the trac control does not disable.
Any ideas as to where to start looking for the problem. This is very annoying in slippery conditions.
Thanks in advance
Old 01-16-2007, 08:00 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: Trac Control won't shut off ?
Sounds more like the other way around. The traction control system is staying engaged since you are not getting a TRAC OFF light.
All traction control functions are handled by the EBTCM module also, which controls ABS.
Timeslip 08/12/06
AF Community Guidelines
Old 01-17-2007, 12:59 AM
MVGTP86 MVGTP86 is offline
check fuse #28 in the fuse box in the engine bay above the battery.
2003 GTP - Brand New L67 crate engine, K&N FWI, Ported TB, 3.4 s/c pulley, Walbro 340 fuel pump, 180* T-stat, 1.9's, PEM'S, ZZP 3" Down Pipe, ZZP 1.0 PCM, gutted cat, u/bend - resonator delete, magnaflow mufflers and tips.
