Go Back   Automotive Forums Car Chat > Saab > 9-5
Old 09-25-2002, 12:33 PM
Fireinthesky28's Avatar
Fireinthesky28 Fireinthesky28 is offline
Send a message via AIM to Fireinthesky28
Question Stock Turbo
Hey does anyone know the standard pounds per inch for the stalk 9-5 turbocharger...If it changes for the different trims, preferably for the standard trim, I don't know what its called...standard or economic or something.
Thnks
So the biblical scholars mis-translated the Hebrew word for "young woman" into the Greek word for "virgin," which was a pretty easy mistake to make, since there is only a subtle difference in the spelling. But back then it was the "virgin" that caught people's attention. It's not every day a virgin conceives and bears a son. So you keep that for a couple of hundred years, and the nexy thing you know, you have the Roman Catholic church.
-Snatch
Old 09-26-2002, 07:56 AM
SaabJohan SaabJohan is offline
9-5 is available with 4 engines, B205E, B235E and B235R and a V6 engine which I don't know the name of. The engines give 150 hp, 185 hp, 250 hp and 200 hp (I don't think the 150 hp B205E is avaliable in the US).
Three diffrent turbochargers are used, B205E and B235E uses a Garrett GT1752 and the V6 uses a GT1549 (integrated with manifold) and the B235R uses a MHI TD04HL-15T-5.
Boost pressure is controlled by the Trionic 7 engine control unit and the pressure varies. The control system is built so that when the driver gives gas he is "requesting" a amount of torque on a given torque curve which the engine then will deliver. To deliver this torque the T7 system will open the throttle, adjust the boost (and many things more) so that the torque given by the engine will be the same as the driver requested.
But there will also be an upper boost limit, for B235R it's 1.5 bar and for B205E and B235E I think it's around 0.5 bar.
Old 09-26-2002, 09:20 AM
Wow...thats pretty impressive...but I guess you shouldn't expect less for 40k.
Thanks, man
-Snatch
Putting stock turbo into non-turbo Z? ShinRekka 240Z | 260Z| 280Z | 300ZX (Past Z Cars) 4 02-03-2003 05:28 PM
Stock Turbo specs Gonthrax Performance 0 04-28-2002 03:05 PM
nissan stock turbo? andyfong Engine 7 12-27-2001 09:35 AM
R33 GTR Stock Turbo Good or Bad 4 2.0ltr cynider Performance 0 12-04-2001 12:28 AM
