Go Back   Automotive Forums Car Chat > Pontiac > Montana/Montana SV6
Old 01-15-2007, 09:09 PM
mymadelynn mymadelynn is offline
2002 Pontiac montana no heat
The heat in our Montana just started not working. If your stopped theres no heat just cold air blows, and when we are moving only warm not hot air comes in. Is the theremostat sticking. There are no lights on the dash and it not low in coolant. Theres no sweat sticky smell either.
Old 01-16-2007, 09:23 AM
LMP's Avatar
LMP LMP is offline
Re: 2002 Pontiac montana no heat
I suggest you check this thread, quite similar
http://www.automotiveforums.com/vbul...d.php?t=663431
'93 Ponty Transport 3.8; 2011 SUzuki SX4 AWD (wife's) ; 2015 Sorento 2.4 AWD 1928 Graham Paige Model 629
I don't believe in miracles.
Old 01-17-2007, 01:37 PM
Judysvan Judysvan is offline
In my '99 Montana, the little flapper valve in air flow opperates by motor and the fuse may be busted. If you hear it move when you switch locations of where the air flow is supposed to go, then that may be ok. Also, if the HVAC air filter (in the glove box of all places) is plugged, the air flow is greatly restricted.
