Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 01-15-2007, 10:59 AM
DOMS's Avatar
DOMS DOMS is offline
Electrical - Rear and interior lights.
It seems that my positive battery terminal came loose while I was driving. Now my interior and rear lights won't come on. I should note that my break lights and turn signals work just fine.
I've check all of the fuses and they all are fine.
What else may be the problem?
Thanks for any help!
I'm not sick, but I'm not well.
1997 Base Eclipse, stock.
Hey, I'm just getting started.
Old 01-15-2007, 11:09 AM
Blackcrow64's Avatar
Blackcrow64 Blackcrow64 is offline
Re: Electrical - Rear and interior lights.
Probably fried something if it came in contact with the hood and the terminal at the same time. If the fuses are fine then chances are you fried some wiring or blew a relay somewhere.
-Brian
  • 92 Firebird sold
  • 97 Talon TSI AWD sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 06 Cadillac STS4 AWD sold
  • 03 Corvette Z06 sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 01-15-2007, 11:12 AM
DOMS's Avatar
Thanks for the info. Is there anything that I can do to help narrow it down?
Also, the connector was just loose, it didn't actually come off of the terminal.
Old 01-15-2007, 11:40 AM
Well if it didn't actually come off and touch anything else at the same time then theres no reason you should have an electrical problem. As long as you tightened it back down then it should have been fine and dandy... What prompted you to check the connection? Did the lights start acting up before you checked it?
-Brian
  • 92 Firebird sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 01-15-2007, 11:45 AM
DOMS's Avatar
When I went to start up the car, it was dead. So I popped the hood and saw what the problem was. So I tighted down the cable and everything, other than the problems I've mentioned, seems to be okay.
Old 01-15-2007, 01:08 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
There is a fuse on the inside of the car, by the drivers left leg. Did you check there. It's labeled I believe tail lights, and it should be a 15amp fuse. I bet you blew that one. I had a major short in my car and that fuse kept blowing. I can almost garentee you that that will be it, unless you fried something.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 01-15-2007, 01:21 PM
DOMS's Avatar
I checked that one. Heck, I checked them all. I even checked the fuses up by the driver-side wheel.
If I "fried something", what would that mean?
Hmm... Well it sounds like it could be from something else besides this. Had any other electrical troubles with it besides this situation?
-Brian
  • 92 Firebird sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 01-15-2007, 01:24 PM
DOMS's Avatar
None. The car is 10 years old, but she's in pretty good shape.
Old 01-15-2007, 02:20 PM
david-b's Avatar
Dave is THAT guy
Just out of curiousity, replace that fuse anyways and see if anything happens. Then there is a wire or something that's no longer intact. However, the fuse should have blown. Jsut replace it for shits and giggles.
75 Monte Carlo
Old 01-15-2007, 07:22 PM
DOMS's Avatar
Will do.
