Old 01-15-2007, 09:46 AM
beretta01 beretta01 is offline
Help Please
Hey everybody.....I have a sub coming today and I just wanted to know how to install it and the amp........ok let me see if i have this right. Ok, I have a mono amp that puts out 800w@2ohm and 450w@4ohm. My sub is a 10" Kicker that is DVC but wired for a single 2ohm load.
----In order to attach the amp to my factory radio i get the line out converter and plug the RCA cables in......run the RCA cables into the input of the amp. Then run some power wire from the batter to the +12 terminal...and then, from what I understand, get any power source and plug it into the "Rem" terminal. Then get ground wire and wrap it around a bolt. Then I guess I just run some wires into the side of the sub and turn it on.
Question I have here is what kind of wire should I use for all of this? What guage for the +12, REM, and ground? And where should I plug the REM into or do i even need to at all? Are their special cables I need to get for the sub to the amp? Thank you soooo much for looking!!
Old 01-15-2007, 12:44 PM
bjboertje's Avatar
bjboertje bjboertje is offline
Re: Help Please
4 ga for +12 and ground, 16-18 or anything you may have lying around for remote. 12 ga for amp to sub. wire the remote to the remote turn on from the radio, should be blue and white.
2001 Ford ZX-2
Alpine CDA-9855
SAX 100.4
Rainbow CMX 265 front stage
Stock 5X7 rear fill
Hifonics BX1505D
TC-5200
Old 01-15-2007, 01:32 PM
jtvyper456's Avatar
jtvyper456 jtvyper456 is offline
Send a message via AIM to jtvyper456
Re: Help Please
Connect your ground wire first . But basically yea, if you want to be fancy with it, you can wire the remote wire into a toggle switch, but it's not really necessary.
1995 Camaro
40 Series Flowmaster
2 Kicker Comp 05CVR 122 (Dual 2Ohm Voice Coils)
^Kicker ZX550.2 Amplifier^
Old 01-15-2007, 02:56 PM
pimprolla112's Avatar
pimprolla112 pimprolla112 is offline
Send a message via AIM to pimprolla112 Send a message via MSN to pimprolla112
Re: Help Please
Go to wally world and get a wiring kit $25 and it has everything you need.
Cant remember who posted it but if you see it give yourself credit
Don't ever look at cars as just imports or domestics. Just because a car is made in a certain country doesn't mean that it is anything like another car from that country. An example of this is Mitsubishi reliability, just because they are Japanese doesn't mean that they are as reliable as a Honda or Toyota.
Cardomain
