Go Back   Automotive Forums Car Chat > Ford > Thunderbird
Old 01-15-2007, 01:16 AM
tbird-pax tbird-pax is offline
Ford Alarm
ok,i armed my car. i locked myself outta da car, but have da key(no keychain alarm). got in, turn the ignition, alarm goes off.didnt know how to stop it, i went to the source. went under the hood and dics da battery. fews secs later i connect da battery agen. from den on, the alarm and evry button on the keychain doesnt werk.........ANY iDEAS?
Old 01-15-2007, 08:43 PM
Loaded NightraiN Loaded NightraiN is offline
Re: Ford Alarm
did you try not using the words 'da' and 'den'??
Old 01-16-2007, 01:58 AM
overl0rd overl0rd is offline
Re: Ford Alarm
You'll probably have to reprogram the keyless entry. There are instructions on the internet, just google it. If memory serves me correctly the module is in the trunk.
Old 01-16-2007, 02:33 AM
Onblsht's Avatar
Onblsht Onblsht is offline
Authorized Vendor
Re: Ford Alarm
These instructions will work on Thunderbird models, 93 - 97:
Turn ignition to RUN or ACC. Momentarily jump pins in programming connector located in LR quarter panel area. All doors will lock then unlock to confirm programming mode. Press any button on 1st transmitter. Door locks will cycle to confirm programming. Press any button on 2nd transmitter (up to 4 transmitters total possible). Turn ignition to OFF. Locks will again cycle to indicate end of programming mode.
Replacement keyless entry remotes available here - up to 90% off -
All makes/models from Acura-Volvo, 1988-present -
http://www.OriginalKeyless.com
Old 01-16-2007, 05:35 AM
Mike75 Mike75 is offline
Re: Ford Alarm
Sorry, I don't speak that language...let alone, type in it.
Old 01-18-2007, 09:46 PM
Re: Ford Alarm
im sorry if i CONFUSED some readers by using "DA"meaning"THE" and "DEN"meaning"THEN",....i just assumed everyone was born with COMMON SENSE. SORRY agen to those readers "dat" "dis" meassage applies to, ill try to be more considerate of others who have mental difficulties...
Old 01-18-2007, 10:10 PM
Re: Ford Alarm
Nope you should know not everyone was born with common sense... I mean if you have the mental capacity to type like that, it obvious you werent ..
Old 01-20-2007, 03:02 AM
Re: Ford Alarm
Noone here is in a position to correct anyone elses grammar.
Old 01-22-2007, 12:44 AM
Re: Ford Alarm
nightrain is gay!!! ...im sure of it...replying to a post to correct one's grammer....lol...umm but thanx for the help nightrain, ill keep "DAT" in mind next time i post "sumthing" i think "u" might read. agen i appologize to all "DAT" is finding it difficult to read what im trying to explain,to those who do understand, i appreciate "URE" help...lol....
p.s. NIGHTRAIN is a FAG...pass it on...lol
Old 01-22-2007, 06:06 PM
Re: Ford Alarm
Because you type like a moron, I'm a fag??
I'm done with this thread
