GA 97 3.1 is this EGR or CAT problem? GENISYS SPX OTC SCANNER WAS USED
I did use different EGR just to test it but I got the same results. If someone is familiar with this scanner – I need some help What is wrong with this picture? STEADY ST CRUS CAT EFF TEST B1 Maximum limit 1135 Measured value 52195 Minimum limit ------ Result Failed ECU 10 EGR CRUISE TEST Maximum limit 0 Measured value 65491 Result Failed EGR DECEL TEST Maximum limit 2 Measured value 65534 Result Failed |
Re: GA 97 3.1 is this EGR or CAT problem? GENISYS SPX OTC SCANNER WAS USED
Sounds like the EGR ports are clogged and giving you a bad reading on the Cat.
![]() Check the wiring around the EGR too . And I was told the GENISYS syst was supposed to be user friendly, and easy for anyone to use
1999 Grand Am SS 3.4 OHV
I also used an OTC Genisys Scanner and got the same EGR values: 65491.
Have you fixed your problem? I just installed a new EGR valve and got that values. You may email me if you like at: [email protected]. Thank you, Tommy. |
Tommy I was not able to find solution to this problem. Maybe we have bad cat
Was the engine warm when these tests were ran? I'd consider trading in that GENISYS scan tool ![]() Does the GENISYS tool even have an exhaust probe?
But did you clean the pipe that the EGR sets on ?
If it has any blockage it can throw off the readings. Whats the readings on the oxygen sen ?
H02S Bank 1 sensor 1v - 0 mv H02S Bank 2 sensor 1v - 447 mv H02S Bank 1 sensor 3v - 9mv I'm currently troubleshooting the PCM. I'm not absolutely positive, but I really feel the PCM is shorted out and causing these problems. I have ordered a new PCM. After I install it, I'll let you know how things turn out. Thank you for your support, Tommy. |
It will be easy with the new pcm if you have that GM PCM programing software on your OTC Genysis. And it is strange that we have exact same reading hmm do not know what to say for that one. What about the other readings that I mentioned above are they close to same? Tell us what engine you have year etc. I can unplug my b1 O2 and measure resistance with engine off and on at the O2 connector that goes to pcm so we can compare the readings that will probably work if you have 96-97-98 3.1l I think and that will probably tell you if you have bad pcm I am not very sure but we can try.
Try also finding wiring diagram for your pcm connectors and see where your b1o2 and b2o2 wires connect to your pcm, unplug your pcm connectors and measure resistances for each wire should be very close to 0 ohms, also clean all your grounds on a car. |
http://ptcruiserworld.tenmagazines.c...ry.ten?id=3504 I have well over 130 pictures with documentation under each picture. Be sure to click on each picture to make them larger. There you will see all of the problems that I have encountered from the start of the project up till now. There have been alot, and I have fixed each problem one by one. However, this one remains to be the most difficult. I don't think the Genisys is capable of programming the PCM, at least not the model that I have. Really not sure, I'm just starting to learn how to use it. It will be able to do a Case Learn procedure that I must get done. Are you familiar with that procedure? As far as the other readings for the EGR, I need to look for my notes on that. I'll get back to you with those readings. Thank you, Tommy. |
people say a picture is worth 1000 words, your 130+ pictures is a library of words
- I saw your pictures and hard work (very nice) there is probably nothing that I can tell you what to try Tommy. You have time, space, will experience and $$$ to try what every you wish all I can say is good luck in finding this solution for us I gave up, but at least I know that I do not need new cat . If you have that color screen otc scanner you can upgrade it so it can test emissions too. http://www.clubgp.com/cgi-asp/mods.asp?modid=48 maybe this can help you for case learn procedure. I never did it but is does not look too hard. If you see any changes in values after new PCM please let me know. [email protected]
EGR Cruiser Test Maximum limit 1 Measured value 65491 Minimum limit --- Result Failed ECU ID 10 EGR DECEL TEST Maximum limit 1 Measured value 65491 Minimum limit --- Result Failed ECU ID 10 Hope this helps. I'll keep you posted of my progress. Thank you all for your support. I really appreciate your help, Tommy. |
I have the same problem Tommy with the pending code p0300. I see misfires on #3 and #4 cylinder. I am sure we have the exact same problem. But one quick question if there is problem with the EGR circuit why don't we have DTC set?, if there is problem with the same circuit how come I can do a test on EGR through PCM and order opening and closing the EGR pintle you can try this on your scanner under special tests. So far the closest I got to stop my misfires was disconnecting MAF sensor that is according to original GM service manual. Manual said if you disconnect MAF and misfires stop replace MAF I did disconnect it and misfires were gonne but when I put in the new MAF the same thing happened. This tells me we have some unmetered air comming in somewhere. Did you do vacuum gauge reading on your intakemanifold? This problem I had for a long time and I was never able to fix it. Hopefully once you get that new pcm I will know if I need to do the same thing. I was thinking to replace all my injectors because of the p0300 but I will wait for this now (I assume you have clean injectors). Back to EGR did you try takaing off the EGR and plugging those EGR openings on manifold with aluminum foil just to see if misfires stop. I am also thinking that this could be problem with one of the valves onot opening or closing properly or bad MAP reading.
Cheap o2 sensors dont last ling, you get what you pay for.
btw Bosch O2's are crap! Quote:
The car should die when the MAF is disconected. I think your guys problem, is the scan tool Or you both have a Bad PCM/ECU, this shouldnt be that much of a mystery to solve.... Maybe you two should test the circuits with a volt/ohm meter, not that GENISYS scann tool.
