Go Back   Automotive Forums Car Chat > Dodge > Durango
Old 01-14-2007, 06:45 PM
chainsm0k3r's Avatar
chainsm0k3r chainsm0k3r is offline
Exclamation Replacing heater core, should I replace the a/c core/heat exchange thing.
I can't seem to find a name for the air conditioning core that's in the heater box with the heater core, I replaced the heater core and in the same box is another condenser type thing for the air conditioner, mind u I'm not the best mechanic but no way I was gonna pay someone to do this &*#@!$* job. I'm shopping for a new, whatever it is. If someone could help me with a proper name for this thing heh. Thanks for ur help.
Old 01-14-2007, 08:08 PM
DurangoDave DurangoDave is offline
Re: Replacing heater core, should I replace the a/c core/heat exchange thing.
That would be called the evaporator coil (the condenser coil is out in the engine bay, in front of the radiator fan).
I'm surprised a parts counter person couldn't tell you that.
I guess you're replacing this because your A/C doesn't work and you've determined this is what's wrong?Anyway, I assume you have the necessary vacuum equipment, etc. to work on A/C.
Good luck.
Let us know how you make out.
Dave
Westminster, MD USA
Old 01-18-2007, 09:06 AM
wafrederick wafrederick is offline
Banned
The a/c has to be discharged if there is a charge in it.Disconnect the battery too,you do not want to set the airbag off.The bad news is that the whole dash and the steering collom have to come out.
Old 02-09-2007, 09:03 PM
DURGIO29 DURGIO29 is offline
how do you change a heater core in a 1998 durango 5.9L
Old 05-30-2007, 12:38 AM
lbrewer4321 lbrewer4321 is offline
Can anyone give me the steps to replace the heater core for a 2001 Dodge Durango?
Old 07-11-2007, 10:07 PM
Superdesmo92 Superdesmo92 is offline
To change out the heater core or the evaporator you need to disassemble almost the entire dash. At least that is what my manual says. I have a bad leak in the dash and the dealer says that is what it is - 8 hours labor plus $350 for the parts. NICE! I am going to try and do it myself.
Old 07-23-2007, 04:25 PM
eseale eseale is offline
Step 1: drive it to the dealer
Step 2: pay them to do it
Step 3: count your blessings you did
The whole dash has to come out and part of the intake. I was going to do it myself also but was lucky to have a neighbor that is a mechanic warn me of it. I thanked him with a beverage after I saw what was involved
Old 07-25-2007, 09:36 PM
Decided to do it myself anyway.
The guy above is not 100% correct. The ENTIRE dash does need to come out, but not part of the intake. I would like to insert a few pics so you can judge for yourself if you want to get involved in this, but I do not know how. If someone wants pics, email me and I'll send you a few.
Definately not for the faint of heart or mechanical skill. I'm about halfway there. Got it all apart and just got all of the parts I need to put it back together. It took me about 6 hours to get this far. The Haynes manual is just good enough to do this if you are really patient. By the way, whether it is the heater core, a/c evap or the BLOWER MOTOR, the dash must come out. Oh but that's not all folks. The entire HVAC unit must be removed. Be careful, there are 4 bolts, not three.
In order - I took out the driver seat, unplug the battery, wait 10 minutes for the airbag to disarm, remove the airbag, unplug all steering wheel plugs, remove all lower panels, remove 4 bolts for the steering column and lower it to floor. Remove the kick panels and upper trim pieces. Then remove center console, glove box, lower support bracket. Then remove the gauge cluster. Be carefull to remove the gear indicator cable from the steering column. The plastic screw threads out, and the cable then comes off. Thread the plastic bolt back into where it came from for safe-keeping. Then remove radio, headlight switch, heater controls (this is not a must, but it makes life easier). Put all fasteners in marked bags, and mark wires. Take lots of pics. Then start removing all of the plugs and grounds that are all over the place. Then remove the 5 screws just under the windshield. Then loosen the two main bolts under each side of the dash. The dash will now rotate back. look for any plugs or grounds you missed - I know you will miss the airbag control plug. And as a bonus - it has an extra catch pin to hold it in place! Now remove the dash, and have a panic attack (I did)!
Now go into the engine compartment. Remove the washer tank, cruise control vacuum motor, airbox and airbox duct. take it slow, and be methodical. Go to the A/C lines. Remove the nut on the rectangular manifold. Then remove the two torx screws, these hold the intermediate manifold to the A/C evap. Now go to the other side, drain the coolant, and remove the two heater hoses that connect to the heater core. Don't even try to twist them off. Just cut them, there is enough hose. Now look for the 4 nuts that hold the HVAC unit to the firewall. The 4th is behind the automatic transmission fill / check tube. NICE. Now go back inside and remove the bracket right in front. Check for any stray connections and mark them. Now pull the unit toward you, take it out and set it on a bench. Now remove all of the screws on top. Then look for a little push fitting toward the left side on top. Be carefull popping it off, or you will break it off like I did. This exploses the heater core and evap.
My evap was completely corroded from these wonderful Buffalo winters (lots of road salt). I talked the dealer and they said this is commo from 1997 to 2001 or 2002. The evaps weren't anodized. DOUBLE NICE!
I will post when I start back together - hopefully this weekend. Two things - I won't be charging the A/C myself so I won't be discussing that, and don't blame me if you get in over your head using my instructions. Just trying to fill in the gaps in the manual (which is good, you just have to jump around a lot).
Another weekend gone. Finally got it all together. Assembly went much faster, just because I laid all of the parts out in the order I took them out of the truck. I think it took me a total of about 12 hours, but I took it really easy. I ended up replacing the resitor element (which is behind the dash under the windshield on the 1999's!!!!) and the blower motor, just because they are so hard to get to. If you do this yourself, take lots of pictures, especially of the routing of wires and the vacuum lines for the HVAC box. Be sure to adjust the gear indicator cable when going back together. Just leave it in park and keep threading the plastic bolt in until the red button is centered in the Park window.
One more thing, if you tackle this job, have a 18V cordles impact handy. This took HOURS off of the job. I have a 18V Ryobi with the ONE+ batteries. This thing delivers 800 in-lb to screws, sockets, etc. It was a massive time saver.
I have yet to have it charged with the R-134, so I will post an update after that.
Old 07-31-2009, 06:49 PM
1bay95west0 1bay95west0 is offline
I am interested in some photos and your progress. Have a 2000 Durango 5.9 which has been diagnosed with a leaking evaporator.
Thanks Z/
Old 08-03-2009, 06:28 PM
jpb53 jpb53 is offline
The post you answered is 2 yrs old. You might try here to get a manual for your Durango.
http://pdftown.com/Pdf-eBook/Dodge.html?from=10
Old 11-27-2013, 04:15 PM
RexHiggins888 RexHiggins888 is offline
Regarding Durango HVAC - The 4th bolt is behind the automatic transmission fill / check tube. NICE. ---> Any suggestions how to get to it? Remove the Tran Dipstick?
