Old 01-14-2007, 05:26 PM
Sad Escort Driver Sad Escort Driver is offline
Clutch starts car
My 1994 Ford Escort had an anti-freeze drip that is now repaired. When I start the car now, I don't need a key, but can just push in the clutch. However, once I try to drive and push in the clutch again, the starter re-engages, making a grinding noise. The wiring all looks fine. What could be the problem?
Old 01-14-2007, 07:27 PM
mightymoose_22's Avatar
mightymoose_22 mightymoose_22 is offline
Re: Clutch starts car
I would suspect something wrong with the ignition switch... but if this problem did not exist prior to the repair, you should take it back and tell them to fix it.
Old 01-16-2007, 09:06 PM
Thanks. I replaced the ignition switch and the car is up and running again.
