Old 01-14-2007, 02:09 PM
brndfrb brndfrb is offline
PassKey III program help
I have a 2003 grand Prix Gt. I got up this morning to go somewhere and the car would not start. The battery is fully charged. Everything works but when you try to start it nothing happends. I have been told it is a ptoblem with the key and that they need to be re programed. What do I do? Please help
Old 01-14-2007, 08:15 PM
troy1 troy1 is offline
AF -Advisor
Re: PassKey III program help
you can try this
1. Turn ON the ignition, with the engine OFF.
2. Attempt to start the engine, then release the key to ON (vehicle will not start).
3. Observe the SECURITY telltale, after approximately 10 minutes the telltale will be steady on as opposed to flashing.
4. Turn OFF the ignition, and wait 5 seconds.
5. Repeat steps 1 through 4 two more times for a total of 3 cycles/30 minutes (the vehicle is now ready to relearn the Passlock™ Sensor Data Code and/or passwords on the next ignition switch transition from OFF to CRANK).
Important
The vehicle learns the Passlock™ Sensor Data Code and/or password on the next ignition switch transition from OFF to CRANK. You must turn the ignition OFF before attempting to start the vehicle.
6. Start the engine (the vehicle has now learned the Passlock™ Sensor Data Code and/or password).
7. With a scan tool, clear any DTCs if needed (history DTCs will self clear after 100 ignition cycles).
