Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 01-14-2007, 01:24 PM
Ticla Ticla is offline
Question Cold start problem
96 crown vic, 4.6L 281 CID engine.
when I use my remote to start engine, the engine crank but dosent start. I have to put my coat on, and crank my self while im pressind the gas pedal, and the engine start.
could somone tell me what could be wrong? is there an adjustement somwhere?
thanks
Old 01-15-2007, 07:33 AM
ponchonutty's Avatar
ponchonutty ponchonutty is offline
Re: Cold start problem
You need a tune up or a new fuel pump. Also, it sounds like your remote start was installed using "voltage sense" which isn't good. It should be tach sensing so it can "see" if the car is running and can adjust the crank time according to what's going on.
Silverado Ext. Cab 4x4 z71
Pioneer 4900mp
Orion P6.2 Componet sets front
Orion C63 Coax rear
DirectedVideo 9" all in one DVD with surround
2007 SATURN OUTLOOK AWD XR with full entertainment package
Old 01-16-2007, 05:31 PM
Tanks, could you tell me what is a good tune up because i did previously replace spark plug, wires, pcv, fuel filter. so what else to do?
Thanks.
i did look in te mecanics manual and i dint foud any place talk about choke or cold start.....
96 Crown vic 90k miles (145.000KM) 4.6L 281 cid V8 Fi
Old 01-16-2007, 06:51 PM
reekor reekor is offline
I had a problem like that once and it turned out to be the coolant sensor for the ecm, it was always reading hot making the engine flood on cold starts. It can also be a bad tps doing this or even a bad IAC.
thanks
His, 96 Limited, 5.2 Magnum, Magnaflow CatBack System, HID Head & Fog Lamps, 242 T-case swapped , Rear Trac-Loc. Chrome grill added to match the wheels.
Hers, 96 Limited I6, 242 T-case, HID Head & Fog Lamps.
Old 01-16-2007, 08:53 PM
/\/\/\/\Bingo The car needs to be on a scanner and have the sensors checked. Something can be bad sensor wise but not actually throw a code but can cause hard starts or worse over a period of time.
Pioneer 4900mp
Orion C63 Coax rear
