Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse 2000+
Old 01-14-2007, 12:03 PM
eclipse2001 eclipse2001 is offline
Unhappy shaking/smoke smell
Hi i have a 2001 eclipse and I recently took the car to the dealer shop to replace the radiator, water pump because it had a leak. So now the car kinda shakes a lot than normal ( stering wheel) and after 5 minutes when im driving the car a smell of smoke or hot temperature water will come inside the hood. Im thinking theres an engine problem my guess. so if anybody knows that the problem i will appreciate your help thanks.
Old 01-14-2007, 10:29 PM
rodbls's Avatar
rodbls rodbls is offline
Send a message via AIM to rodbls
Re: shaking/smoke smell
What do you mean when you say "hot temp water comes inside the hood"? If you took it to the dealer for them to fix it, and now something else is weird, take it back and tell them they fucked up and need to fix it right.
2000 Fed. Spec GT-"Lafawnduh"
Mods: SPEC 2+ Clutch, Fidanza Flywheel, PowerStop Rotors, Red Stuff Pads, Stainless Brake Lines, B&M Short Shifter, Energy Suspension Shifter Bushings, Deyeme Firm Motor Mounts, KYB AGX shocks with Eibach Proline springs, Halo Projector Headlights with HID 12000K Conversion, TYC Carbon Tails, Kicker SS6.5 Component Front, SS MB8 Custom rear, Tsunami 2F Capacitor, ***New Stuff*** JVC KD-AV7010 In Dash DVD Player, Kicker L7 12" Woofer, Kenwood KAC-X10D Mono Amp
Old 01-15-2007, 04:52 AM
brad02420's Avatar
brad02420 brad02420 is offline
I think what he means is hes getting a burning smell from under his hood or "hot temp. water" smell in his case?
Whatever the case maybe, you need to take it back to the place that done the work and let them find the problem and fix it. Also dont let them charge you more money because it sounds like its something they fucked up.
North Star White 2000 Eclipse GT 5 Speed.
Mods-Greddy EvoII Exhaust System,Injen Cold Air Intake,Megan Racing Short Shifter,ES Shifter Bushings,Greddy Counter Weighted Shift Knob, Fidanza Lightweight Flywheel, Prothane Motor and Trans Mounts,Clear Corner Lights,APC Euro Tail Lights,Mio C520 GPS,Passport X50 Radar Detector,Sony Xplode HU.
Old 01-15-2007, 11:43 AM
rodbls's Avatar
well, it for sure sounds like they fucked something up, because if they replaced/fixed the radiator, and now it smells like hot liquid...they obviously didnt do something right. And yeah, dont let them tell you something else needs to be fixed because they should have found that when they fixed the first problem.
