Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 01-14-2007, 11:45 AM
cyclescientific cyclescientific is offline
P0300 code w/o cause? need help
I just had another engine put into my 2002 Rodeo (2WD - 3.2L V6). I keep getting the P0300 code but the engine runs smoothly, has new plugs, and i checked all of the coils for continuity (they all showed 3k Ohm on my multimeter.) Any ideas? I can't help but think something other than the plugs and coils is causing the code to pop up.
Old 01-14-2007, 12:07 PM
Re: P0300 code w/o cause? need help
I forgot to mention that the check engine light flashes while accelerating but then stops when the engine is idling or not under load.
Old 01-14-2007, 01:19 PM
amigo-2k amigo-2k is offline
Isuzu Guy
what kind of plugs did you put in it? It will toss a flashing CEL if you stick other brands then what it came with.
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 01-14-2007, 06:05 PM
trooperbc's Avatar
trooperbc trooperbc is offline
did you clear the codes ? they stay in memory until you do.
//bc
1992 trooper 3.2L v6 sohc automatic...as is
i love a good intermittent electrical challenge. . .especially when it's someone else's.
Old 01-14-2007, 09:15 PM
Cat Fuzz Cat Fuzz is offline
Yep, the newer Rodeos are really picky about spark plugs.
Old 01-15-2007, 09:24 AM
I cleared the codes numerous times and it keeps coming up (I have my own OBDII in the glove box with the Haynes manual.) I searched around a bit and noticed all the talk of the spark plugs so I ordered some of the Denso plugs (the OEM double platinum) from sparkplugs.com. If that doesn't fix it I can't think of anything else. When the engine was replaced, so were all the gaskets plus the guy does good work so I suspect all the sensors were thoroughly cleaned. Just pisses me off that I just got my car back with a low mileage engine thrown in and it runs smooth as butter minus the damn CEL constantly flashing.
Thanks for the help guys - this is definitely a solid forum (unlike some others I've tried to use in the past.)
cheers,
James
Old 01-16-2007, 06:38 PM
2eyefishclaw's Avatar
2eyefishclaw 2eyefishclaw is offline
Send a message via AIM to 2eyefishclaw Send a message via Yahoo to 2eyefishclaw
poor ground at the intake could cause this thats where the ground is for the Ion module
Old 01-23-2007, 08:52 AM
Thanks for all the help guys - I messed with it a bit and turned out to be two things:
1. The mechanic that swapped the engine didn't put the coils on in the right order (namely, the cyclinder #6 specific coil was on cyclinder #2)
2. Wrong plugs - I put some denso's on. The NGK plugs also work (thats what I had on the old engine.)
Old 01-23-2007, 04:43 PM
surferfletch surferfletch is offline
Thanks for the solution.
1997 Isuzu Rodeo LS 3.2L V6 SOHC 4L-30E Dueler Alenzas 4x2
1997 TJ Sport 4.0L D35 rear 5 spd 31" Dayton Timberline ATs
1996 VW Jetta GLS 2.0L 5 spd
