Go Back   Automotive Forums Car Chat > Cadillac > Deville
Old 01-14-2007, 09:38 AM
Dreamchaser Dreamchaser is offline
Question 2002 Deville
I have a 2002 Deville with 78600 miles on it. I am getting a slight burning smell from the car when it is ran for a while. I have checked all the fluids and everything is full. I have also checked the belt to see if there is any signs of wear and that is okay also. The car was at the dealers for a problem not to long ago and they fixed that no problem. They didn't spot any other problems then either. Does anyone have an idea what is causing this smell???
Old 01-14-2007, 12:46 PM
DFBonnett DFBonnett is offline
Re: 2002 Deville
Probably a tiny oil leak. Valve cover gaskets are often the culprit, allowing a bit of oil to drip onto a hot exhaust manifold. It could be other things also. The best way to find it is to look harder for any leak, oil coolant, or transmission.
Good luck.
Old 04-22-2009, 10:51 AM
Loonylani Loonylani is offline
Re: 2002 Deville
Sometimes my tires make that smell. It's from driving around turns on 2 wheels maybe? j/k
My tires really do stink after driving at higher speeds or long distances though.
