Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 01-14-2007, 02:15 AM
mtcs's Avatar
mtcs mtcs is offline
Send a message via AIM to mtcs Send a message via MSN to mtcs
Unhappy DSMLINK problems!! HELP PLEASE!
In my eclipse i seem to be having a problem. When I go past 6000 RPM, my clutch seems to disengage. I have DSMlink and am sure that there is something setting wise that controls that. It is weird the Rev limiter is at 7500 and it cuts off at 6000rpm. When I am in 1st,2nd, or 3rd, all RPMs are ok. Then in 4th and 5th anything above 6000rpm disengages the clutch. Every part I just put into the car was brand new and now has less than 700 miles on everything.
The motor and tranny are brand new so they cant be broken yet.
Does anyone know what this could be caused by?
Thanks
1996 ECLIPSE GST
2.3 Storker, 6 bolt, XACT flywheel, ACT Clutch, B&M shifter, DC SPORT Carbon steel strut tower bars, EVO2 exhaust, 1000cc injectors,Aeromoive rail, MBC boost controller, PTE 6152SP, SBR exhaust manifold, TIAL BOV, SBR FMIC, TEIN SS, Walbro fuel pump, AEM EMS, AEM UEGO, FP turbo intake, Aeromotive FPR, Magnus intake, 62mm throttlebody, Stoptech big brake kit, brembo rear slotted discs, Stage 2 Shep transmission (quafe), sparco fighter seats, sparco harnesses
Old 01-14-2007, 08:29 PM
ez1286's Avatar
ez1286 ez1286 is offline
Send a message via AIM to ez1286
Re: DSMLINK problems!! HELP PLEASE!
I don't think that has anything to do with dsmlink. If the clutch is disengaging thats something mechanical. Link has nothing to do with that.
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff.
http://www.ratemydsm.com/member/ez1286/?member=ez1286
Old 01-17-2007, 02:50 PM
northendtrooper's Avatar
northendtrooper northendtrooper is offline
uh why you going past 6k rpms?
Old 01-17-2007, 03:34 PM
ITSME4G63 ITSME4G63 is offline
Send a message via Yahoo to ITSME4G63
http://www.dsmlink.com/forums/
1993 Eagle Talon Tsi Awd 5SPD - Teh Great White
Chitownevo - Chicagoland's local evo forums
Old 01-17-2007, 04:54 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Originally Posted by ITSME4G63
No one can access that unless they have a dsmlink account and password....
95 Talon TSI AWD
97 Eclipse GST
Old 01-17-2007, 05:47 PM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
My question also. You say it only happens in 4th and 5th...why the hell are you trying to go above 6k in those gears? You must be goin pretty damn fast to even be able to get it that high in those gears...
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 01-17-2007, 07:49 PM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
What do you mean it disengages the clutch? Unless I am mistaken, link doesnt have anything to do with the clutch. Do you mean you are hitting a rev limiter and it wont rev past 6k? Or is it getting there and revving higher but not making the car go? I see you have an ACT clutch, but which one? Depending on your tune and the clutch disk, you may be slipping the clutch. I dont think your problem is link though, I bet its something else.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
