Old 01-14-2007, 12:47 AM
naruto's Avatar
naruto naruto is offline
Banned
sub not working
hey all
i have just anstalled a kenwood kdc-mp333 head unit and my problem is when i listen to the radio the sub works perfectly but when i switch to cd mode itr stops working.
there is a wire that has p-cont(think it means power continuous or something). I am not sure if im supposed to connect that wire to something to make the amp work as i've never seen that color wire(blue/white stripe)
Help asap would be greatly appreciated
Thanks
Old 01-14-2007, 12:03 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
Re: sub not working
the problem is most likely that you have connected the power antenna wire to the amp auto-turnon, it is only powered when the radio is on. There is a dedicated auto turnon wire on the headunit you're supposed to use.
Old 01-14-2007, 10:12 PM
PlayStation3 PlayStation3 is offline
Re: sub not working
yea it is called the remote turn on wire. usally is the blue and white one
Old 01-14-2007, 10:31 PM
Darrick147's Avatar
Darrick147 Darrick147 is offline
Send a message via AIM to Darrick147 Send a message via Yahoo to Darrick147
Re: sub not working
Yeah they're right because I had the same problem with mine when i first hooked up my system...it usually is the blue and white wire. You may have connected it to the solid blue wire.
Old 01-15-2007, 03:06 AM
naruto's Avatar
Banned
Re: sub not working
yeah you guys are correct. i fixed it last night.
Thanks for the replies though
