Old 01-13-2007, 10:47 PM
nickrolando nickrolando is offline
2000 Grand Prix Radio Removal
I just need to remove the radio to install XM satellite radio. I'm installing the wired fm transmitter and i need to know how to pull out the factory radio.
Old 01-13-2007, 11:00 PM
MVGTP86 MVGTP86 is offline
Re: 2000 Grand Prix Radio Removal
You just pull off the dash and theres a couple screws you take off that hold the radio in place and pull it out, thats it. Very Simple.
2003 GTP - Brand New L67 crate engine, K&N FWI, Ported TB, 3.4 s/c pulley, Walbro 340 fuel pump, 180* T-stat, 1.9's, PEM'S, ZZP 3" Down Pipe, ZZP 1.0 PCM, gutted cat, u/bend - resonator delete, magnaflow mufflers and tips.
Old 01-13-2007, 11:08 PM
Hey man, I own a older mustang so that shit is alot easier then newer cars. This is my moms car and i dont wanna screw it up. Can you give me any better direction then "you just pull the dash off"?
Old 01-14-2007, 08:58 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Click here
Timeslip 08/12/06
AF Community Guidelines
Old 01-14-2007, 11:40 AM
Originally Posted by bnaylor
That says 97-99
Old 01-14-2007, 12:12 PM
I pulled out the radio and pushed it back in and the RED LCD Display where it displays the song #, or the radio station # is blank. You can see the radio station is really dark. The Red LCD Display is not there.
BNaylor's Avatar
It is the same procedure for 2000 and up as far as removing the dash panels. Take it or leave it.
Timeslip 08/12/06
Old 01-14-2007, 12:13 PM
The RED LCD Display, is not lighting up anymore. It is blank with the letters in dark red. The blacklight is black and not red like it was before.
Old 01-14-2007, 01:08 PM
Someone please help i opened it up and check the bulb and the bulb looks fine.. doesnt look burnt out.
What are all the fuses that relate anything to the radio.
Old 01-16-2007, 02:59 PM
Help Please
Old 01-16-2007, 03:19 PM
BNaylor's Avatar
What work did you do when you removed the stock radio? Was the battery negative cable disconnected before starting work? Even though the lamp looks good did you check it with a multimeter and ohm it out? Hopefully, you did not burn out the display driver IC.
Timeslip 08/12/06
