Go Back   Automotive Forums Car Chat > Chrysler > Lebaron
Old 01-13-2007, 08:27 PM
oldengrey oldengrey is offline
'88 Lebaron Fuel Pump Prob
Why does the fuel pump keep running after ignition turned off and key removed? '88 2.2 T1, A/T, Tilt Wheel No Air Bag.
Old 01-14-2007, 11:06 AM
4pt9fiero 4pt9fiero is offline
Re: '88 Lebaron Fuel Pump Prob
My guess would be a sticking/bad fuel pump relay. The relay should be located somewhere under the hood.
Old 01-29-2007, 01:49 PM
Joric theredbaron's Avatar
Joric theredbaron Joric theredbaron is offline
After consulting Haynes.. power to the fuel pump is controlled via the Automatic Shutdown Relay. This is located on the right side of the engine bay behind the battery attatched to the inner fender. Its the smaller of the 4 or 5 boxes.. i dont think tis the one attatched to the strut tower tho..
Hope this helps
Joric
Friends dont let friends drive imports
Old 01-30-2007, 11:33 AM
2lazy 2lazy is offline
Hope this helps
This sir is correct. It would be the Shutdown relay. Just did this last year. Took me a few days to figure out the problem too. DONT FORGET TO USE NEW ENDS IF THE WIRES LOOK CORRODED. In my case it wasnt really the relay, but the associated wiring. So bust out an ohm meter and test test test. Might not need a relay at all! :\
Old 01-31-2007, 04:17 PM
Thanks 2Lazy.. I should have mentioned the wiring as well.. lolol..
Joric
