Old 01-13-2007, 07:21 PM
camryman98 camryman98 is offline
Send a message via AIM to camryman98
Possible setup??
Right now I have a Kenwood Kdc-217 headunit. and A. Single channel 300watt amp Hooked up to a Kicker comp 12. My friend just got Some new equipment for his truck and he is going todo some major off roading and he needs to get rid of his subs and amps. No matter what I am going to by them because of the deal he is giving me because we are friends. But the set up he is giving me is. 2. 12" Kicker compvx. And 2 seperate Planet Audio TT850D amps.
My old headunit only has 1 set of pre-outs. So the question is. Is there some type of splitter. Or someway to supply power and signal 2 both amps. Or do I have to buy a new headunit with 2 sets of preouts.
Thank you for your time.
Evan.
Old 01-13-2007, 09:01 PM
Darrick147's Avatar
Darrick147 Darrick147 is offline
Send a message via AIM to Darrick147 Send a message via Yahoo to Darrick147
Re: Possible setup??
Each amp should have a set of RCA outs and RCA ins...u just have to run one RCA cable from the head unit to the In RCA on one amp and then run another RCA cable from the out on that amp to the RCA in on the other amp. If that makes sense.
Old 01-13-2007, 11:30 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
most amps that I have seen do not have RCA outputs. You can get a set of rca Y-cables, they split one input to two out outs.
Old 01-14-2007, 12:01 AM
jtvyper456's Avatar
jtvyper456 jtvyper456 is offline
Send a message via AIM to jtvyper456
A picture will explain a bit better:
That should be the setup of the TT850D. Run one set of RCA cables from the headunit to the input of one amp, and then run another set of RCAs from the output of that amp into the input of the second amp.
1995 Camaro
40 Series Flowmaster
2 Kicker Comp 05CVR 122 (Dual 2Ohm Voice Coils)
^Kicker ZX550.2 Amplifier^
Old 01-14-2007, 11:12 AM
Audio Guy
oh, ok .... that's not a normal setup. So are these amps strapable, if not what is the data link for ?
Old 01-14-2007, 02:28 PM
bjboertje's Avatar
bjboertje bjboertje is offline
yeah, must be strappable, has master/slave switch too.
2001 Ford ZX-2
Alpine CDA-9855
SAX 100.4
Rainbow CMX 265 front stage
Stock 5X7 rear fill
Hifonics BX1505D
TC-5200
Old 01-16-2007, 06:14 PM
Audio Guy
do you not have an owners manual for these amps ?
Old 01-16-2007, 10:06 PM
Dunno Im buying them from a friend and I dont Know if he has them. Ill ask asap. But I was asking you if you could help me tweak it cause Im NOt really sure what all the lil knobs do.
Old 01-16-2007, 10:44 PM
pimprolla112's Avatar
pimprolla112 pimprolla112 is offline
Send a message via AIM to pimprolla112 Send a message via MSN to pimprolla112
LIke paul said y-splitters radio shack gold series $5 each.
AS for the power they have distribution blocks just make sure the power kit you get can handle the power you throw at it RMS not peak.
Cant remember who posted it but if you see it give yourself credit
Don't ever look at cars as just imports or domestics. Just because a car is made in a certain country doesn't mean that it is anything like another car from that country. An example of this is Mitsubishi reliability, just because they are Japanese doesn't mean that they are as reliable as a Honda or Toyota.
Cardomain
Old 01-17-2007, 05:20 PM
Audio Guy
to "tweak" it, I would have to know the reat of your system
