Old 01-13-2007, 02:57 PM
SlackerOfSociety's Avatar
SlackerOfSociety SlackerOfSociety is offline
Power wire problem
Hello. I just installed a new system in a friends car. I ran into a problem. He has a side terminals battery. The metal loop on the power wire will not fit between the battery and the positive terminal. If I put it between the two the terminal will not screw into the battery, as the screw is too short. My question is does anyone sell a clip (like the kind on jumper cables) that I can crimp to the end of the power wire and clip it onto the terminal post? Or does anyone else have any suggestions? I am sorry if this doesnt make any sense, i tried my best to explain. Thanks
Old 01-13-2007, 05:47 PM
jtvyper456's Avatar
jtvyper456 jtvyper456 is offline
Send a message via AIM to jtvyper456
Re: Power wire problem
Just hook it to the positive lead of where the battey cables lead to...not sure what the darn thing is called....
1995 Camaro
40 Series Flowmaster
2 Kicker Comp 05CVR 122 (Dual 2Ohm Voice Coils)
^Kicker ZX550.2 Amplifier^
Old 01-13-2007, 06:17 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
if you are gonna run large cables, you usually have to use a special battery post connector.
Old 01-13-2007, 07:54 PM
Can you elaborate on that a little more? I am a little confused.
Old 01-13-2007, 07:56 PM
Is the connector the red cable that screws into the battery? or is it some sort of adapter?
Old 01-13-2007, 08:58 PM
jtvyper456's Avatar
Instead of hooking the amp straight to the battery, hook it to where the cable coming off of the battery leads...I'm not positive on what it's called...that's what I did with mine.
1995 Camaro
Old 01-13-2007, 09:00 PM
Doesnt the positive cable coming from the battery lead to the alternator?
Old 01-13-2007, 09:18 PM
jtvyper456's Avatar
Not straight to it, at least my 95 Camaro's doesn't...it leads to a small box that has the positive and negative bat. cables, I can take a pic if necessary...trace the cable and see where it leads
1995 Camaro
Old 01-14-2007, 12:21 AM
pimprolla112's Avatar
pimprolla112 pimprolla112 is offline
Send a message via AIM to pimprolla112 Send a message via MSN to pimprolla112
Go to walmart and get this gold battery terminal looking thing, it has connectors for 4 wires to go into it and a piece to connect it to side terminal batteries. I put the cars cable behind that connector and hooked the amp wire up to one of the 4 holes in it.
Its like $12
this is kind of what it looks like but it has 4 connectors on the side instead of 3. Just go back to the car audio section at wally world and they should have it. If not autozone or advanced might have it.
http://cgi.ebay.com/BATTERY-TERMINAL...QQcmdZViewItem
Cant remember who posted it but if you see it give yourself credit
Don't ever look at cars as just imports or domestics. Just because a car is made in a certain country doesn't mean that it is anything like another car from that country. An example of this is Mitsubishi reliability, just because they are Japanese doesn't mean that they are as reliable as a Honda or Toyota.
Cardomain
Old 01-14-2007, 12:26 AM
PlayStation3 PlayStation3 is offline
herer this is what you need. http://www.circuitcity.com/ssm/Tsuna...oductDetail.do
here is a cheaper one http://cgi.ebay.com/New-Nickel-Silve...QQcmdZViewItem
Old 01-14-2007, 11:20 AM
Originally Posted by PlayStation3
Thanks to everyone who responded! I think I will go with what PlayStation3 posted, looks the easiest! Thanks PlayStation3!
Old 01-14-2007, 02:32 PM
bjboertje's Avatar
bjboertje bjboertje is offline
that would be the main fuse box.
i would not do that as that wire is usually on the small side, like 6 or 8 guage or so. connect directly to the battery with at least 4 guage using one of those terminals.
2001 Ford ZX-2
Alpine CDA-9855
SAX 100.4
Rainbow CMX 265 front stage
Stock 5X7 rear fill
Hifonics BX1505D
TC-5200
