Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '96-'00 Civic
Old 01-13-2007, 01:27 PM
evojunkie333 evojunkie333 is offline
civic turbo kit, how many psi?
ok i bought a turbo kit for my civic 1.7 liter, sohc, how many psi can i safely run without popping an expensive motor, ive heard, 5, heard 7, and have heard i can go as high as 9, anybody no the safe limit for a stock motor? thanks
Old 01-13-2007, 02:00 PM
AudioGuy93DelSol's Avatar
AudioGuy93DelSol AudioGuy93DelSol is offline
NA is Best!
Send a message via AIM to AudioGuy93DelSol
Re: civic turbo kit, how many psi?
All in the tuning, but I wouldn't go higher than 8.
Oil leak? What oil leak? That puddle under the car is just sweat from all that horsepower.
"How many NASCAR passes is that worth? 500?" (Schumacher passing Raikkonen)
Emily is amazing, and she messed with my sig AGAIN!
Old 01-13-2007, 08:11 PM
NA is Best!
No need to post the same question in more than one section. Please refrain from doing that again.
Old 01-14-2007, 01:06 AM
Schister66's Avatar
Schister66 Schister66 is offline
AF -Advisor
Send a message via AIM to Schister66 Send a message via MSN to Schister66
Oh i live for questions like this!!
You can't base ANYTHING off of PSI. It varies depending on the turbo. For most D series engines, 230whp seems to be the limit. From now on, when you talk about power, talk in hp and not in psi. Also, if you think D's are expensive, you are sadly mistaken...they are a dime a dozen. The worst part of blowing a D up is that you have to fix it...the cost isn't bad at all.
I want to here more about this setup and what it consists of....pics and details ASAP!!
2015 DGM STi - 2006 SGM STi - 1999 Built/boosted GSR
Old 01-30-2007, 03:41 AM
exman98 exman98 is offline
on a typical set up around 8 psi BUT as stated befor not all turbo's are created equal!!!!!!! i larger turbo can make more power at the same PSI of a smaller turbo
so you are asking me what should you make? Ummmmm.... well i vote meth lab.....helps out the community and gives people like you a job
I love out driving people.
"what's all those cylinders for anyway"
