Go Back   Automotive Forums Car Chat > Ford > Escape | Maverick | Escape Hybrid
Old 01-13-2007, 11:53 AM
MyNeoN95 MyNeoN95 is offline
Engine Light on EGR valve
01 Escape
33000miles not exact
The engine light came on took it to auto zone for a test and they said it was the ERG valve, To spray carb cleaner down it . I removed the EGR it look clean, no build up. Should I spray cleaner, or is there something else I could do? Thanks
Old 01-14-2007, 02:40 AM
KimMG KimMG is offline
AF - Advisor
Re: Engine Light on EGR valve
Use a vacuum pump and test it. Make sure the vacuum lines are good. Check the parts that the EGR is connected to.
Old 01-15-2007, 09:57 AM
AlohaBra's Avatar
AlohaBra AlohaBra is offline
Cool Re: Engine Light on EGR valve
Try this link:
http://www.automotiveforums.com/vbul...d.php?t=449603
From a poster on AF:
"It appears that Ford has had problems with their Differential Pressure Feedback Exhaust Recirculation Valve. (DPFEGR). Most of what I read linked this trouble code to the EGR valve Pressure Sensor. (DPFEGR - same thing). Right now it is a Dealer Only Part."
EDit: I have had three put in mine..it is easy to change. Pull a code.
Old 03-22-2007, 10:30 PM
AlohaBra's Avatar
Got a P0401 again ....cleared it with the code checker.
Might need to replace the egr pressure differential valve again.....
Aloha....
Old 03-25-2007, 09:43 AM
AlohaBra's Avatar
Light on again, ordered a new Egr differential pressure switch from:
http://www.fordpartswebsite.com/escape.html
Old 04-03-2007, 11:14 PM
AlohaBra's Avatar
UPDATE:
You can reset the light using the code checker tool.
New part was installed for this error: P/N 4U7Z-9J460-AA
Internet purchase: $62.51 including shipping and (No) tax
Old 04-14-2007, 09:20 PM
papiichuulo papiichuulo is offline
AF Premium User
Check local autoparts for an "EGR Pressure Sensor". That is the name given to it by them...
Old 04-16-2007, 10:27 PM
AlohaBra's Avatar
so.. did that fix your problem...??
Mine was fixed...
Ordered a new Egr differential pressure switch from:
Old 07-31-2008, 11:21 AM
Panama88 Panama88 is offline
I have a 2002 Ford Escape V6 with 130,000+ miles. The emmissions light came on and AutoZone checked the error code (for free). It was P0402, Exhaust Gas Recirculation Flow (EGR) Excessive Detected. The possible problems were either the EGR valve or EGR sensor (DPFEGR) was bad.
After researching, a lot of people seemed to think there was better chance of the sensor going bad than the valve. I purchased a new sensor ($40 at Pep Boys) and installed it in minutes. (Quicker then unhooking the battery connection.) It did the trick! Light is off and I passed emmsiions inspection this morning.
If anyone gets this code, I would recommend replacing the sensor. It's cheap and simple to do yourself.
Old 08-02-2008, 10:23 AM
AlohaBra's Avatar
Thanks for the update. I did not know Pep Boys had this part, but that makes sense since this part commonly goes bad.
