Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 01-13-2007, 11:38 AM
kozykids kozykids is offline
replacing 90 camry horn
Horn stopped working last year but then started again. Stopped again, can hear a clicking (the relay, right?) when I press the horn and hazards do work. I located the horns and removed one, there is a wire that ran into a boot coming off the horn, when I removed the horn the wire just slid out of the boot. I also saw that there was another harness connecting onto the horn and one end of the plastic connection was broken off. I saw no wire going into the boot on the second horn, that harness was intact though. So my questions are:
Should there have been a wire going into the second horns boot?
If so should it have come from the other horn or where the wire leads out going to the first, and I have no idea what the contraption is the wire is coming out of
Here is a link to photos I've taken.
http://www.kozykidswear.com/horn.jpg
Any help advice would be appreciated. And yes I will be replacing the horns, any tips on how to do this would be great.
Thanks
Old 01-13-2007, 01:20 PM
DFBonnett DFBonnett is offline
Re: replacing 90 camry horn
On my '93 the diagram shows a green/white wire from the relay going to each horn. You can download a manual here
http://oregonstate.edu/~tongt/camry
and see if it shows you anything.
