Go Back   Automotive Forums Car Chat > Chevrolet > El Camino
Old 01-13-2007, 11:06 AM
frogman6042 frogman6042 is offline
1980 rear window
my rear window is rattleing and leaks any body else had this problem and is it fixable everything seems fine are did someone just throw it in there any info will be great ...........
Old 01-14-2007, 09:03 PM
rhandwor rhandwor is offline
Re: 1980 rear window
Go to a parts store and buy some windshield sealant. Any thing from rust to movement from age can cause a leak. Just to do a neat job and this should fix you up. It even comes in tubes you can use in a caulking gun.
Old 02-15-2007, 06:15 AM
SolRaven's Avatar
SolRaven SolRaven is offline
I don't know the history of the vehicle, but if the glass was changed without changing the seal that might be the cause. if you don't want to gunk it up with sealer, and are up to it I would suggest removing the window and seal and putting a new one in. while you have it out you will be able to see whats under it, who knows what you will find. if you do decide to remove it be vary careful that is an expensive piece of glass.
I will also ask if you have had a substantial leak back there. i had one case where the vertical body lines below the rear window started separating. if this is the case you should remove the window use c-clamp vice grips to close the gap and have an experienced welder braze them together, and possibly the bed line while your at it. Brazing shouldn't leave nasty beads or holes like a mig welder.
Old 03-07-2007, 10:41 PM
Classic_V8 Classic_V8 is offline
I just got my 71 el camino rear window fixed because water would get through. They took off the rear window and found rust holes which were closed by welding. its fixed!
