Go Back   Automotive Forums Car Chat > Pontiac > 6000
Old 01-12-2007, 08:51 PM
gmbwrenchn gmbwrenchn is offline
Thermostat location
Where is the thermostat located on this car? '90 6000 LE 3.1 LTR.
Also, they offer a replacement one @ 195* or 180* I want to get heat in the car asap! Which one to get? Thanks.
Old 01-13-2007, 06:02 PM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: Thermostat location
The easy way to find the thermostat is to follow the upper radiator hose back to the engine. Where it connects is the thermostat housing. You my have to remove several items to get to it. Go with the 195 degree stat. That should be stock and should get you the most heat.
Old 01-13-2007, 06:54 PM
Thanks, all set.
On another note........you {GTP Dad} had helped me with a 95 Grand Am with a head gasket issue. She has been doing well. No leaks and plenty of compression. Just wanted to say thanks, again.
