'97 Grand Prix SE 3800 Wiper Problem
I have a '97 Grand Prix SE 3800 and just the other day my wipers stopped working. when i pushed the washer solution the wipers don't work. I checked the fuse and everything is fine. Is it the motor? Or the relay? If it is the relay, where is it?
Phill |
Re: '97 Grand Prix SE 3800 Wiper Problem
To start there is no relay.
The 12 volts from the WIPER FUSE feeds directly to the Multifunction Switch (Stalk) at the steering column and from there direct to the wiper motor assembly. Even though the fuse may look good make sure you have 12 volts at the fuse socket. You are either missing 12 volts to the MFS switch, bad MFS switch, wiper motor or possible mechanical problem like the wiper transmission.
