Old 01-12-2007, 03:14 PM
raven1245 raven1245 is offline
Car Stall Problem
So, I installed an amp yesterday just to find out it was broken, and the nearest store with a replacement was half hour away. So as I was driving there this morning, after driving about 10 mins or so, when I would use the brakes, the headunit would go off then on. So after this happened once or twice I took off the faceplate. Then another 10 mins later as I was going on the offramp when I hit the brakes, the car completly stalled. I tried starting it again but it was completly dead. So I got out and took off the power wire from the battery and the ground cable in the trunk, and then it started again. I had the power wire covered up, so it wasnt grounding to there. But its also strange how it was with the brakes/brakelights that the car stalled. I checked the power wire once through and didn't find any nicks or anything in it. Anyone have any ideas?
Old 01-12-2007, 03:30 PM
jtvyper456's Avatar
jtvyper456 jtvyper456 is offline
Send a message via AIM to jtvyper456
Re: Car Stall Problem
Check the battery on the car, also--if you are grounded in a bad place, the amp will refuse to operate, check and see that the power wire sparks by QUICKLY touching it to the ground wire, if it sparks, then you're ground is good...if not, you need a better grounding place. Check and be sure the remote wire has power also .
1995 Camaro
40 Series Flowmaster
2 Kicker Comp 05CVR 122 (Dual 2Ohm Voice Coils)
^Kicker ZX550.2 Amplifier^
Old 01-12-2007, 03:35 PM
Right now (and during the problem) I dont have anything hooked up. It was just the amp wire connected to the battery and going to the trunk, and the ground wire hooked up to a bolt in the trunk. I don't want to hook anything up til I can at least get an idea of what happened, so I dont risk damaging anything.
Old 01-12-2007, 11:38 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
if you're car works fine without the wire, it's doing something ..... could be a lot of things unfortunately.
Old 01-13-2007, 12:12 AM
jtvyper456's Avatar
The bolt in the trunk could be your problem as of why the amp didn't work , as I said before, test the power wire by quickly touching it to the ground, if it doesn't spark, you have either an extremely bad ground, or a bad power wire. As far as your car stalling, it could be one of the Big 3 wires shorting, millions of other possibilities, go get your alternator checked at autozone or something--they do it for free.
1995 Camaro
Old 01-13-2007, 01:12 AM
pimprolla112's Avatar
pimprolla112 pimprolla112 is offline
Send a message via AIM to pimprolla112 Send a message via MSN to pimprolla112
Or do it the safe way using a DMM, you can cause some issues later on if you do that. IT might not sound bad but if the fuse blows then you obviously put way to much current to it, and if it doesnt then you could be causing damage to the cars electrical system.
Cant remember who posted it but if you see it give yourself credit
Don't ever look at cars as just imports or domestics. Just because a car is made in a certain country doesn't mean that it is anything like another car from that country. An example of this is Mitsubishi reliability, just because they are Japanese doesn't mean that they are as reliable as a Honda or Toyota.
Cardomain
Old 01-13-2007, 11:20 AM
Audio Guy
After being a tech for 20+ years, I would never do something like that.
Old 01-14-2007, 02:18 PM
bjboertje's Avatar
bjboertje bjboertje is offline
i bet your battery is bad. get it checked at autozone or somthing.
2001 Ford ZX-2
Alpine CDA-9855
SAX 100.4
Rainbow CMX 265 front stage
Stock 5X7 rear fill
Hifonics BX1505D
TC-5200
