Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 01-12-2007, 03:11 PM
tdpittsburgh tdpittsburgh is offline
98 explorer no wipers, dome lites, windows etc.
my 98 explorer has no wipers, dome lights or chimes, the windows don't work but the locks and side mirrors do. the radio is on but i can't adjust the volume or change the channel. dash lights are on everything works except the speedometer, the heat works, the horn and cig lighter. i checked all the fuse and none are blown but not all are getting power. please help, it's raining.
Old 01-12-2007, 05:19 PM
Dr98 Dr98 is offline
Re: 98 explorer no wipers, dome lites, windows etc.
Hi
Check these fuses on the inside panel for the GEM module- # 25, 10, 28, 20.
Dean
Old 01-16-2007, 06:32 PM
all fuses ok
all the fuses are ok, it is the GEM Module. I have to replace it. What is the best price to look for. Can I put one from a wrecked explorer in my explorer?
Old 01-16-2007, 08:29 PM
denisb denisb is offline
Re: all fuses ok
You should be good with one out of a wrecked explorer. Most wrecking yards will give you some sort of warranty (probably 30 days) and will know which are compatible with your year and options. Make sure to bring all the info on your Explorer (year, model, motor size, 4 door/2door etc) if you don't call ahead.
Denis
Old 01-22-2007, 05:29 AM
i'd like to change the gem module myself, does anyone know where it is located and how hard it is change it? thanks
Old 01-22-2007, 11:59 AM
shorod's Avatar
shorod shorod is offline
SHO No Mo
I'll have to check the service manual tonight, but typically the GEM is sandwiched between the instrument panel fuse panel and the firewall (the fuse panel rides piggyback to the GEM).
-Rod
Old 01-25-2007, 10:32 PM
shorod's Avatar
SHO No Mo
I was wrong. Per the 1998 Ford Truck Service Manual:
Module -- Generic Electronic (GEM)/Central Timer (CTM)
Removal
1. Disconnect the battery ground cable.
2. Remove the radio chassis.
3. Remove the center instrument panel finish panel.
1. Remove the screws.
2. Remove the center instrument panel finish panel.
3. Disconnect the electrical connectors.
4. Remove the GEM/CTM.
1. Remove the screw.
2. Disconnect the four connectors from the GEM/CTM.
3. Remove the GEM/CTM.
-Rod
