Old 01-12-2007, 12:08 PM
fergymoto fergymoto is offline
3.0L SOHC Torque Specs?
I cannot for the life of me find torque specs for the 3.0 liter SOHC motor I am building for a friend's Stealth. Does anyone know, have a book or anything? Thanks!
Old 01-12-2007, 12:10 PM
Igovert500's Avatar
blue + red light magnet
Re: 3.0L SOHC Torque Specs?
Specifics? Which are you looking for. A few of us have service manuals. Plus alot of stuff can be found by searching on here or stealth316.com
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 01-12-2007, 12:18 PM
Primarily I need the main cap torques, rod bolt specs, and head bolt specs. None of my local Dodge dealers can dig anything up, their info supposedly doesn't go that far back. Don't have a local Mitsu dealer. It is a 1993 Stealth. Thanks for the quick response!
Old 01-12-2007, 01:16 PM
Igovert500's Avatar
This should do it
And as the headbolt sequence was just discussed on here a few days ago, here is it is from the manual.
(thanks Andrew)
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 01-12-2007, 02:02 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
for the SOHC, the torque spec is same as the DOHC non-turbo. 80 ft-lbs. its not listed in the illustration, what i recall that's what the manual says.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 01-12-2007, 02:33 PM
Thanks a ton guys! I really appreciate it.
