Old 01-12-2007, 11:35 AM
Mac Fan's Avatar
Mac Fan Mac Fan is offline
Send a message via Skype™ to Mac Fan
Something is wrong...
I always thought astonishing the BMW S70/2, a very high specific output with so much torque. I have seen these figures in many places: 479 lbft - 4000-7000. But then I discovered the formula that says: Power = Torque x Angular Velocity, that can be simplified like you see here
If you use the formula you discover that if it had 479 lbft on 7000 RPM, it would have about 638 hp, which is impossible since the max. power is 627 hp at 7400 RPM.
I always assumed it was wrong, but I want to know your opinion. I still wonder what would be the real figures. If someone could put it on a dyno...
"... but it's opening this throttle which you just cannot believe how quick this car goes." - Tiff Needell
Old 01-12-2007, 05:22 PM
amanichen amanichen is offline
Re: Something is wrong...
Here's the engine:
http://s94779296.onlinehome.us/F1_dynograph.jpg
Peak torque is at around 5600RPM.
Old 01-12-2007, 06:06 PM
Mac Fan's Avatar
Originally Posted by amanichen
Here's the engine:
Thank you very much. That is exactly what I needed.
Old 01-12-2007, 06:27 PM
Peloton25's Avatar
McLaren Fanatic
amanichen is our resident calculations expert.
>8^)
ER
Old 01-13-2007, 02:55 AM
hurstg01's Avatar
hurstg01 hurstg01 is offline
Good find amanichen
Instagram/
Old 01-23-2007, 10:29 AM
F1GTRUeno F1GTRUeno is offline
is the rumour true about XP5's engine (this has probably been asked a lot)
Old 01-23-2007, 10:57 AM
Peloton25's Avatar
McLaren Fanatic
Actually, I am not quite sure which rumor you are referring to?
>8^)
ER
Old 01-23-2007, 11:13 AM
supposedly it was fitted with a pre-production/prototype engine which was less powerful that the production engines
Old 01-23-2007, 11:33 AM
Peloton25's Avatar
McLaren Fanatic
That may be true originally, but by the time the top speed run was done in 1998 I assume that would have definitely been rectified. Otherwise, McLaren would have used a different car I am sure.
>8^)
ER
Old 01-24-2007, 06:16 PM
>8^)
ER
You're probably right. When I did my calculations a few months back, I found that the car needs 602hp pushing it through the air (that's wheel horsepower) at 240mph. The 550hp engine, even with an increased volumetric efficiency from the 240mph headwind, probably wouldn't have worked very well for that =)
