Old 01-12-2007, 11:13 AM
cflygirl cflygirl is offline
Window Washer issue on 92 Park Ave
My window washer fluid thing has quit working. At first the washer would only work if the tank was full, once it got to half a tank then it would quit working. But now even with a full tank of washer fluid it still does not work. I have replaced the motor for it twice and it still does not work. It really is a pain when the snow starts melting up here and your window gets covered and you have no way to clean it off when your out in the country. Any suggestions?
Old 01-12-2007, 11:54 AM
Loekee75's Avatar
Loekee75 Loekee75 is offline
Send a message via Yahoo to Loekee75
Re: Window Washer issue on 92 Park Ave
When you say it quits working, doyou hear the pump motor but get no fluid, or is the motor not working at all? Have you checked all the hoses for restriction?
http://www.cardomain.com/ride/2653398
1992 Buick Park Avenue (Daily driver)
2001 Saturn SL1 (gas saver)
Old 01-12-2007, 11:58 AM
You can hear the pump motor going, but nothing comes out. I have checked for blockage or holes in the hose and I saw nothing.
Old 01-12-2007, 12:03 PM
Loekee75's Avatar
Hmm...what about the water outlets above the firewall?
Old 01-12-2007, 12:05 PM
I don't think those have been checked yet... never thought of that.
Old 01-12-2007, 04:51 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Wink Re: Window Washer issue on 92 Park Ave
Did you check and clean the screen located on the end of the rubber hose in the reservoir? If you have small debris in the lines, you may have to use low air pressure to blow it out.
