Old 01-12-2007, 11:09 AM
cflygirl cflygirl is offline
Power window problem on a 92 park avenue
Just the other day my front driver side winow decided to quit working. It won't roll up, but it will still go down without a problem. Is the window motor bad? How do I go about taking off the door panel in order to replace the window motor?
Old 01-12-2007, 11:57 AM
Loekee75's Avatar
Loekee75 Loekee75 is offline
Send a message via Yahoo to Loekee75
Re: Power window problem on a 92 park avenue
Sounds to me like your switch is going out. The contacts for the up position make be worn or dirty. The switch panel in your armrest can be removed by prying it out in the front (facing front of car) with a small standard screwdriver. Underneath, the switch can be removed and tested.
http://www.cardomain.com/ride/2653398
1992 Buick Park Avenue (Daily driver)
2001 Saturn SL1 (gas saver)
Old 01-12-2007, 12:03 PM
How do you go about testing it?
Old 01-12-2007, 12:06 PM
Loekee75's Avatar
what you could do is remove the current switch and swap it out with one of the others. If your window works properly after that, then you pretty much narrowed it down. If you have a voltmeter you can test the switch with it. You can also take the switch to most auto parts stores and they'll test it for free.
Old 01-12-2007, 12:15 PM
Sounds like a good idea to me. I'll have to try that later today. Is it easy to swap out the switch to test another one in its place?
Old 01-12-2007, 12:52 PM
Loekee75's Avatar
The switches easily unclip with a small screwdriver, it's not difficult to do.
