Old 01-12-2007, 09:50 AM
Phillip Cross Phillip Cross is offline
Power window regulator
Just purchased an aftermarket window regulator and motor assembly for my 2000 2dr. Do I need to find a big enough rivet gun to install or can I use bolts and nuts. Besides taping the window in the up position are ther any tricks?
thanks
Old 01-12-2007, 09:54 AM
Ultrashock's Avatar
Ultrashock Ultrashock is offline
Re: Power window regulator
thanks
Bolts and nuts are fine thats what I used. Taping the windows up did not work that well so I stuck a stick in the door and it worked perfectly
92 S10 Blazer Sport
4.3l Vortec V6 (W)
275,000 miles
Jasper engine, Rebuilt tranny + rearend
04 Pontiac Grand Prix GT
43,000 miles
Old 01-23-2007, 03:54 PM
Just finished. It was hard to get all three guides lined up at the same time . It took a little moving the window up and down with a helper.
The main reason for the post, however, is to confess what a bone head I am. Once I hooked up the new motor it did not work. after fooling around for a while I found that the exisitng connectoron the switch side was not tight. This means that the old motor was OK. I checked for power at the motor before ordering the new part, but I guess the probe made better contact than the motor end of the connector.
Live and learn. nevertheless, I guess I still saved some over taking to the shop and I have new regulator and motor and a spare.
