Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 01-11-2007, 12:12 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Thumbs up Got new outer tie rods...
When I got my new tires and took it in for an alignment, I was told that the outer tie rod on the passenger side. The wheel, when off the ground, could wiggle. They showed me how the tie rod was moving and such. Today I took it in, and they tried it again, same deal. They tried the drivers side again, and it was a little wiggly also. So I got both replaced, and and alignment. $250 for both rods, alignment, and labor. I love those guys.
I thought that the tie rods were the ones making the popping noise when I turn. However, it still continues to make that noise. So now I've replaced the lower control arms and the tie rods, and still the sound persists. What else can that be? Shocks maybe. It's only on the passenger side while making a turn. Grr. It's not a total loss though. I did those tie rods and an alignment badly.
HTML Code:
Front:              Left   Right
Camber:              0.1    0.0
Cross Camber:          0.1
Toe:                 0.08  0.03
Set Back:              -0.37
Rear:
Camber:              -1.2   -1.2
Toe:                 0.11   0.13
Very badly needed it. She still pulls to the left, so I'm going to take it back in next week. Got a 6 month warrenty with it. Any other ideas on what the popping noise is? Thanks
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 01-11-2007, 01:10 PM
Blackcrow64's Avatar
Blackcrow64 Blackcrow64 is offline
Re: Got new outer tie rods...
Balljoint?
-Brian
  • 92 Firebird sold
  • 97 Talon TSI AWD sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 06 Cadillac STS4 AWD sold
  • 03 Corvette Z06 sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 01-11-2007, 02:00 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Were the control arm bushings replaced when the control arms were replaced? I had to replace a set on a grand am and anytime you would turn or hit the brakes it would make a popping noise.
95 Talon TSI AWD
97 Eclipse GST
Old 01-11-2007, 04:47 PM
david-b's Avatar
Dave is THAT guy
When they got replaced, new ones came with. Even afterwards I took to the dealer bc of the recall and they resealed them and checked them out also. So I'm stumped.
75 Monte Carlo
Old 01-11-2007, 05:01 PM
NOFX0617's Avatar
NOFX0617 NOFX0617 is offline
Send a message via AIM to NOFX0617
You said it happens when you turn...does it only happen when you turn a certain way or just turning no matter what direction?
1998 Eclipse GSX
6 Bolt swap
MHI Big 16g
FP Race Manifold
Apex'i N1 Cat-back
Apex'i N1 Downpipe
Walbro 255 fuel pump
GReddy Type S BOV
Turbo XS Boost Controller
Balance Shaft Elimininator
ACT 2600
RRE 11lb No Name Flywheel
Prothane Motor Mounts
Tokico Illuminas Advanced Handling Kit
RRE Front and Rear strut tower bars
RMDSM Front and Rear Sway Bars
TRE Stage 2 Tranny
ARP Head Studs, Main Studs, Rod bolts
Old 01-11-2007, 05:29 PM
And how about when you turn just sitting there, or only when you're driving?
95 Talon TSI AWD
97 Eclipse GST
Old 01-12-2007, 08:33 AM
david-b's Avatar
Dave is THAT guy
It doesn't happen all the time. Happens when turning mostly, but will do it also when accerlating sometimes too. It's actually worse now since yesterday. I'm going to take it back in one day and have the alignment fixed and to see if they can find what it is. I'm stumped.
Talking to one of my buddies yesterday, his cousin had a car that also made a popping noise just like mine. She spent over $800 on just that one side to try to fix it. Ball joints, arms, struts, axles, and it still did it. He said it sounds exactly the same as mine. Grr. That kinda makes me angry.
75 Monte Carlo
Old 01-12-2007, 11:42 AM
When you bring your car to get an alignment, see if they can put it up on a lift to get all the wheels off the ground, then just grab every suspension component you can see and jerk the shit out of it, something has to be loose/banging around.
95 Talon TSI AWD
97 Eclipse GST
Old 01-13-2007, 10:12 AM
david-b's Avatar
Dave is THAT guy
That's what they did when they saw that the tie rods were bad. I was there watching them. Nothing made that noise. The only thing that showed any signs of stress and ware were the tie rods. Do you think the struts could be causing it?
75 Monte Carlo
Old 01-13-2007, 10:17 AM
alphalanos alphalanos is offline
popping sound= cv joints?
96 EJ6. Future home of boosted B18C1.
Old 01-13-2007, 03:34 PM
Struts could cause it if one was very badly fucked up, or even if the mounts were loose (which probably isn't the case)
95 Talon TSI AWD
97 Eclipse GST
Old 01-14-2007, 08:32 PM
ez1286's Avatar
ez1286 ez1286 is offline
Send a message via AIM to ez1286
I concur!
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff.
http://www.ratemydsm.com/member/ez1286/?member=ez1286
Old 01-18-2007, 12:07 PM
Stabilizer bar bushings could be dried out and that could be causing your popping... Did you check that yet?
-Brian
  • 92 Firebird sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 01-18-2007, 02:12 PM
Mikelb's Avatar
Mikelb Mikelb is offline
Send a message via AIM to Mikelb
I third for CV joints, sounds like a worn outer joint... they clunk/pop when turning... it can also make noises accelerating/decelerating... especially when it's a sudden change in speed or direction...
Originally Posted by Blackcrow64
I write a lot... I wrote one song about this chick I was messing with that was uhhh... Well, lets just say I called it "Forbidden Love"
1991 Eagle Talon TSI - Broken
Head removed, block broken, trans in hatch
1991 Eagle Talon TSI AWD- in pieces
3" exhaust, rebuilt bottom end
Project: Assemble the Eagle is underway... and now with AWD
2003 Lancer Evo 1630hp/1593ft lb tq
