| 240Z | 260Z| 280Z | 300ZX (Past Z Cars) The original Z cars - ones that started it all. |
90' na auto swap to tt manaul
hey thanks for the info, ive been looking for something to help me out. i have a 90 n/a auto, and i found a wrecked tt manaul. is it much work to change over to manaul? also if i have the tt whole car, is there anything else i would need to do the install or does it pretty much just change over? thanks for any info u could give me.
Re: 90' na auto swap to tt manaul
http://twinturbo.net/net/viewmsg.asp...msg_id=1001493
http://twinturbo.net/net/viewmsg.asp...&msg_id=962729 http://twinturbo.net/net/viewmsg.asp...&msg_id=916979 http://twinturbo.net/net/viewmsg.asp...&msg_id=874620 http://twinturbo.net/net/viewmsg.asp...&msg_id=746049 Also, PM k3smostwanted, he's done it.
1989 240SX Fastback. . . . . . . . . . . . . . . . . . . . . . . . . . . 1995 300ZX Twin Turbo ![]() Warning: Objects in mirror aren't as fast as they thought they were. |
pretty easy swap. you need the tranny, shifter, different driveshaft or the half shaft of the 5-speed driveshaft as long as you also have a 2seater, slave cylinder and master cylinder along with clutch pedal, hydraulic lines from master to slave, clutch assembly including pressure plate, and flywheel.
beings you will be using a TT transmission you will need a TT flywheel for the starter to reach the gear ring of the flywheel. the TT flywheel is also heavier and bigger so i do not know how much this will effect the performance of your N/A motor. may notice a slight drag but the 5-speed may offset the problem. shouldnt be noticeable reguardless. there are also a few tricks with wiring to get the reverse lights and the speedometer to read correctly. good luck. its really not that bad of a swap.
ZedEx Crew Member #4
yeah sry i am just trying to finger out the problems that i might run into before i jump into the swap. im buying a 93 tt manaul for 1,500. it has upgraded ecu, greddy exh, one peice driveshaft, shiftkit, and some stillen ground control something. do u think this is a good deal? its comming with everything on the car, it even still runs. but the back end is wrecked. can i just strip the tt and just replace everything on my car for the most part? plan on up grading all the brake lines, and prob clutch lines. i called around to a few shops and one told me for 3,500 to 5000 they would do the tt and manual swap. for that price i would rather do it my self,lol. they were also telling me that u have to pull the wiring harnest out of the cassie, or something like that. anyideas? thanks
do some research...the net is flooded with information about TT swaps on 300zx as it is becoming a common thing.
are the splines different on a manual n/a driveshaft, than a manual TT driveshaft?
