Old 01-11-2007, 08:30 AM
thedeadcivic's Avatar
thedeadcivic thedeadcivic is offline
Temperature Gauge
im trying to hook up a temperature gauge and ive already got it mounted and ive routed the wire through my firewall but i cant find the connection on the engine block to attach the sensor.
anyone know where i would find it? its a d16a6
90' Honda Civic Si
2001 Volkswagen Golf 1.8T
Old 01-11-2007, 08:34 AM
turtlecrxsi's Avatar
turtlecrxsi turtlecrxsi is offline
Send a message via AIM to turtlecrxsi
Re: Temperature Gauge
The temp switch that turns on your fan is on the back of the engine underneath the intake manifold. It has 2 prongs and plastic cover. I believe it's right above the oil filter. The temp sensor is under the distributor closest to the front of the car if I remember correctly. Why are you hooking up a separate temp gauge? Why didn't you just splice it to the existing temp gauge on the gauge cluster?
2008 KIA Spectra5 SX
2010 Honda CR-V EX
Old 01-11-2007, 10:32 AM
the gauge i got isnt electric so i cant splice the wires. i had the gauge so i put it on with a pillar set thing. might as well hook it up. anyways, im at work now but ill check for it when i get home. thanks
90' Honda Civic Si
Old 01-11-2007, 06:24 PM
Tony's Avatar
Tony Tony is offline
TLD Member #1
Send a message via AIM to Tony
The one right by the oil filter would be the oil pressure switch. I hooked mine up on the thermostat housing replacing the sensor there, but that was on a z6, but thermostat housing is where i would check first, it will give you enough room for the sensor in the housing.......atleast i think it was the thermostat housing, lol, it where the one of the hoses connects on the back side of the head.
Tony
91 Civic Sedan DX - Stock 287k Miles
Old 01-11-2007, 06:33 PM
FrodoGT's Avatar
FrodoGT FrodoGT is offline
Isnt electric?! what? so your going to try and stick a probe on your engine and expect that to work?
Cheap, Fast, Reliable..Pick two
Current project:
Rio Red 91 hatch.
A6/Z6 build, Hondata S300, Tokico illumina/Ground Control.
"I'd rather run 12's on steelies than 15's on rotas."
Old 01-11-2007, 10:01 PM
Tony's Avatar
TLD Member #1
Mine worked perfectly fine...ofcourse my fans were hooked up to a switch too so that wasn't of any concern. I got alot better reading out of the aftermarket gauge than the factory one.
Tony
Old 01-11-2007, 11:35 PM
www.iequus.com
yeah.
90' Honda Civic Si
Old 01-12-2007, 06:09 PM
viper-blue's Avatar
viper-blue viper-blue is offline
electric is the only way to go...wait til your temp line burst and you get a wif of that ether...electric is so much cleaner if you ask me
89 crx SI - spoiler, custom viper blue paint job, Z6 just completed, stock 14's with a 3 inch drop, sidemarkers, and the stereo
"my crx is like my woman: don't like anyone touching her, or driving her but me!"
Old 01-15-2007, 06:42 PM
Mtrujillo's Avatar
Mtrujillo Mtrujillo is offline
Send a message via AIM to Mtrujillo Send a message via MSN to Mtrujillo
I would have to agree with this guy, it's also less of a hassle to install. The only mechanical gauge I have is my oil Pressure gauge.
- Marlon
カーブのキラー
DigitalHorizon
Old 01-15-2007, 07:10 PM
FrodoGT's Avatar
Hate to see the inside of your car, or for that matter, you..when that hot oil line busts into your cabin, mine is electric.
Current project:
Rio Red 91 hatch.
Old 01-15-2007, 07:25 PM
Tony's Avatar
TLD Member #1
Wow, you guys are just completely against mechanical gauges. I trust them over the electrical, no change of shorts. And I haven't had a problem with either of my mechanical gauges(water and oil) and they are under quite a bit of pressure racing all the time. Now I will agree the electric water is less of a hassle, and probably reusable, unlike the mechanicals, which usually break once you got to remove them.
Tony
Old 01-16-2007, 03:13 PM
Mtrujillo's Avatar
Hahahaha....that only happens when you let incompetent people do your installs. In all the years of using Mechanical gauges I have never ever once had a problem and like Tony I run my cars hard.
Mechanical Gauges FTMF!
- Marlon
カーブのキラー
DigitalHorizon
Old 01-16-2007, 03:14 PM
Mtrujillo's Avatar
- Marlon
カーブのキラー
DigitalHorizon
Old 01-17-2007, 09:26 PM
now i just need an adapter to fit the existing sensor.
btw, mechanical gauges are more reliable as long as your not a dumbass...
you shouldnt have any problems with them as long as you run the line through your firewall properly and keep it away from moving parts...
and i dont think the oil pressure gauge acctually runs hot oil into the cabin.
90' Honda Civic Si
Old 01-17-2007, 09:35 PM
FrodoGT's Avatar
It does, it doesnt circulate the oil but itll get just as hot as the engine.
Current project:
Rio Red 91 hatch.
