| Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible. |
Transmission kicking... not moving
hey. i have a 98 mitsu eclipse automatic.
car was bought about 1 year ago. dealer said that the transmission was rebuild but we didnt bother to think much of it... and about 6 months ago we had a transmission prob, so we got it fixed via AAMCO, and now its messed up again... this is pretty much what i feel... When the car is put into drive, there is no prob...until i decide to release the brakes... the car slowly begins to roll, then starts kicking as if i was riding a horse... or something.. it move 1 inch at a time... and doesnt move at all...like not even 1 mile per hr... the most i can do is roll... what could that be?? The transmission was changed once before we got it, once 6 months in, and now... is this common in eclipses?? what could it be?? its really annoying... and i kinda need my car to get to work...
Re: Transmission kicking... not moving
Do you remember what the problem was with it before and what they did to fix it? Also, what model eclipse do you have RS, GS, GST, or GSX?
1998 Eclipse GSX 6 Bolt swap MHI Big 16g FP Race Manifold Apex'i N1 Cat-back Apex'i N1 Downpipe Walbro 255 fuel pump GReddy Type S BOV Turbo XS Boost Controller Balance Shaft Elimininator ACT 2600 RRE 11lb No Name Flywheel Prothane Motor Mounts Tokico Illuminas Advanced Handling Kit RRE Front and Rear strut tower bars RMDSM Front and Rear Sway Bars TRE Stage 2 Tranny ARP Head Studs, Main Studs, Rod bolts |
The mitsu is a GS non turbo... i think the problem last time delt with the torque converter... or some solenoid... not too sure... but definately one of the 2...im gonna go with the torque converter.
Uhh...have you checked the fluid?
Do you have access to another transmission computer that you could swap in to see if it makes a difference? It may be the TCU.
With an automatic I believe ur supposed to check the fluid with the vehicle running in park or neutral. Don't shut if off and check the fluid.
98 Eclipse GSX-EVO3 16G, BC 272's,ETS FMIC and short route piping,TRE Stage 2 tranny, ACT 2100, Walbro 190lph,550cc jectors,SAFC NEO,GM MAFT, AEM UEGO wideband,ported SBR Exhaust Manifold,O2 Dump,EBay Intake,3" megan downpipe and catback exhaust,TurboXS boost controller,HKS BOV,Ebay Short Shifter,Boost Gauge,Symbroski shift kit & shift cable bushings, RRE catch can 94 Talon 1.8L-SOLD 02 Civic EX- Daily driver (staying stock) Last edited by TalonEclipseMixGsx; 01-12-2007 at 04:42 PM. |
Correct, you're supposed to wait till the vehicle is at normal operating temperature, cycle through ALL the gears, and then check the fluid with it in park while running.
