Old 01-10-2007, 07:00 PM
Crx Guy Crx Guy is offline
90 Crx Wiring Diagram
I was wondering if any one had a good Wiring Diagram for a 90 Crx... I think HF. At any rate I just need it to connect up some wires for the B16 I am putting in it.
Thx for your Help
Old 01-10-2007, 07:32 PM
FrodoGT's Avatar
FrodoGT FrodoGT is offline
Re: 90 Crx Wiring Diagram
If your putting in a B16 then the wires are already there. You just need to run 3 extra wires, one for the knock sensor, one for the vtec solenoid, and one for the vtec oil pressure switch. The HF engine harness will fit right onto the b16.
Cheap, Fast, Reliable..Pick two
Current project:
Rio Red 91 hatch.
A6/Z6 build, Hondata S300, Tokico illumina/Ground Control.
"I'd rather run 12's on steelies than 15's on rotas."
Old 01-10-2007, 08:28 PM
Hybrid1990crx's Avatar
Acutally you have to run 4. knock, vtec sol, vtec oil, and 2nd o2.
This is the diagram I use when wiring on a mpfi car:
Old 01-10-2007, 10:39 PM
hondacivic99sivtec's Avatar
hondacivic99sivtec hondacivic99sivtec is offline
Send a message via Yahoo to hondacivic99sivtec
you can just tap into the 1st o2 if youe don't wanna run the wire all the way to the front. but that's the ghetto way.
-tony-
2000 honda s2000
Old 01-11-2007, 04:28 PM
FrodoGT's Avatar
Yes forgot to mention the second O2.
Current project:
Rio Red 91 hatch.
Old 01-11-2007, 08:31 PM
bambam89lx's Avatar
bambam89lx bambam89lx is offline
AF - Advisor
Send a message via AIM to bambam89lx
The car will run, but this is not good because you're splitting the voltages.
Jumper harnesses, mpfi conversions, engine harness conversions, vtec subharnesses, etc.
The absolute lowest prices at the absolute highest quality. Trusted. Guaranteed.
Click the image above to visit our online store!
Hastings Bseries and Dseries piston ring kits (inc. ZC) - $49 shipped
Old 01-12-2007, 12:58 AM
well that's why it is the ghetto way. lol go obd-1. way nicer
-tony-
2000 honda s2000
Old 01-12-2007, 12:31 PM
bambam89lx's Avatar
AF - Advisor
Or, run BRE or turboedit. The only difference between OBD1 and OBD0 is the 02 sensor. If you're running a wideband, it doesn't really matter.
