Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 01-10-2007, 06:35 PM
Gusto222 Gusto222 is offline
Send a message via AIM to Gusto222 Send a message via Yahoo to Gusto222
Exclamation :: HELP :: Removing an ALternator
How do i remove an alternator from a 1998 mitsu eclipse??
-- non-turbo : 2.0 : 2wd
Please HELP!
~Gusto~
yeah i know i cant spell....
'96 civHB:shaved:19" rims:3000w stereo -- SOLD
'97 Tacoma:2wd:lifted -- SOLD
'00 Dakota.QC:lifted:33"tires ---SOLD
'06 Mazda3.GT:Eibach:mazdaspeed I/E
Old 01-10-2007, 09:43 PM
TalonEclipseMixGsx's Avatar
TalonEclipseMixGsx TalonEclipseMixGsx is offline
Re: :: HELP :: Removing an ALternator
Look in a Chiltons manual for the exact bolts and screws to loosen. But if you look at the alternator its pretty much self explanitory. You have the bolt ont the bottem the lets it pivot to tighten or loosen and then one at the top which is connected to that metal bracket with the track. Im going off of memory here. Ive done it 3 times in my talon and once in my eclipse, but im sure they are all basically the same. Make sure you disconnect the battery before doing all of this. You will also have the connector on the alternator to unplug and the power wire attatched to it that u need to disconnect. That should be about it.
98 Eclipse GSX-EVO3 16G, BC 272's,ETS FMIC and short route piping,TRE Stage 2 tranny, ACT 2100, Walbro 190lph,550cc jectors,SAFC NEO,GM MAFT, AEM UEGO wideband,ported SBR Exhaust Manifold,O2 Dump,EBay Intake,3" megan downpipe and catback exhaust,TurboXS boost controller,HKS BOV,Ebay Short Shifter,Boost Gauge,Symbroski shift kit & shift cable bushings, RRE catch can
94 Talon 1.8L-SOLD
02 Civic EX- Daily driver (staying stock)
Old 01-10-2007, 10:32 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
It's a fuckin BITCH. It's back behind the motor on the passenger side of the car in the corner towards the bottom, it's hard as hell to physically get out. You have to unbolt the tensioner bolt (14 or 15mm wrench/socket), unplug the connector, unbolt the battery cable (10mm socket) and then unbolt the actual "swivel" bolt. Good luck.
95 Talon TSI AWD
97 Eclipse GST
