Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 01-10-2007, 05:38 PM
NateS's Avatar
NateS NateS is offline
Send a message via AIM to NateS
Help identify this sensor
I am in the middle of installing my new head and I have to use my old cam gears. I did not have an impact gun handy to remove the center bolt on the cam gears so I had to remove the camshaft and the camgear together. When I took the intake cam/cam gear out there was a sensor right behind the intake cam gear on the outside of the head that I broke. What is this sensor called and where can I get one?
95 GSX 5 speed
2.3L stroker bored .020 over
Built head
Bullseye/Borg Warner T04B 57 Trim Turbo
RNR 3" turboback w/ o2 eliminator
255 lph Extreme Motorsports fuel pump
Extreme Motorsports mbc
SAFC
Greddy Type S BOV
FMIC (core 28x10.5x3.5)
FIC 650cc fuel injectors
RK Sport Fuel Pressure Regulator
My Car Domain
Old 01-10-2007, 06:57 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Re: Help identify this sensor
Is it on the opposite side of the gear? That would be the cam angle sensor
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 01-10-2007, 07:56 PM
NateS's Avatar
No it is on the same side as the gears. Infact it looks like it sat right behind the intake cam gear.
95 GSX 5 speed
Built head
SAFC
Greddy Type S BOV
My Car Domain
Old 01-10-2007, 08:33 PM
david-b's Avatar
Dave is THAT guy
I remember that's only on the turbo models. I want to say its the the cam angle sensor. I think Talon69s took a shit and he had problems. I'm not 100% sure.
75 Monte Carlo
Old 01-10-2007, 09:04 PM
NOFX0617's Avatar
NOFX0617 NOFX0617 is offline
Send a message via AIM to NOFX0617
Yeah sounds like the cam angle sensor...its almost in the exact spot as the intake cam gear but on the other side of the head right...
1998 Eclipse GSX
6 Bolt swap
MHI Big 16g
FP Race Manifold
Apex'i N1 Cat-back
Apex'i N1 Downpipe
Walbro 255 fuel pump
GReddy Type S BOV
Turbo XS Boost Controller
Balance Shaft Elimininator
ACT 2600
RRE 11lb No Name Flywheel
Prothane Motor Mounts
Tokico Illuminas Advanced Handling Kit
RRE Front and Rear strut tower bars
RMDSM Front and Rear Sway Bars
TRE Stage 2 Tranny
ARP Head Studs, Main Studs, Rod bolts
NateS's Avatar
Okay quick questions http://members.shaw.ca/dsm.1000q/Eng...mer/1G/cas.htm I know that is a 1G but, on my 2g head that CAS is not in that location and does not look like that. Instead there is something that looks like a plastic cap that goes in that spot. I am guessing the only place I can get a new cap for that spot is the dealership. Since my CAS is not on the opposite side(where the cap is) I am assuming the sensor I broke(behind intake camgear) is the CAS.
95 GSX 5 speed
Built head
SAFC
Greddy Type S BOV
My Car Domain
Old 01-10-2007, 09:05 PM
NOFX0617's Avatar
so its this one right
http://members.shaw.ca/dsm.1000q/Eng...mer/2G/cas.htm
1998 Eclipse GSX
6 Bolt swap
MHI Big 16g
FP Race Manifold
Apex'i N1 Cat-back
Apex'i N1 Downpipe
GReddy Type S BOV
ACT 2600
TRE Stage 2 Tranny
Old 01-10-2007, 09:13 PM
NateS's Avatar
No, like I said. There is nothing that looks like that installed on that side of my head. There is a black cap in the hole where that CAS would go. The sensor I am talking about is on the same side as my intake cam gear. It is a very small looking sensor.
"Some early 2G DSMs have this sensor mounted on the crankshaft itself" <<Thats me.
95 GSX 5 speed
Built head
SAFC
Greddy Type S BOV
My Car Domain
Old 01-10-2007, 09:19 PM
defiancy's Avatar
defiancy defiancy is offline
Stay classy San Diego
Yep, that would be more correctly called the Crank Angle Sensor.
1991 GSX 2.3 Stroker
Old 01-11-2007, 02:18 AM
NOFX0617's Avatar
Sorry I read that wrong...and if its on the head then it wouldnt be the Crank angle sensor would it? I know mine is down on the crank. I am really not sure though man... I just got done taking my entire head and block apart and I dont remember any sensor right there...
1998 Eclipse GSX
6 Bolt swap
MHI Big 16g
FP Race Manifold
Apex'i N1 Cat-back
Apex'i N1 Downpipe
GReddy Type S BOV
ACT 2600
TRE Stage 2 Tranny
Old 01-11-2007, 07:26 AM
defiancy's Avatar
If it's on the head than it's the Cam Angle Sensor
Old 01-11-2007, 03:06 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Yepp. Camshaft Position Sensor (CMP) if it's on the end of the head. A picture would verify if you could get one.
95 Talon TSI AWD
97 Eclipse GST
Old 01-11-2007, 04:25 PM
NateS's Avatar
Camshaft posistion sensor makes sense. I just took another look at the head and the sensors. On the left side(facing car from front of car) where the CAS pictured in the links is, there are wires ran there for a sensor but there is a connecting wire that goes into it then runs down towards my block where I am guessing the CAS is located. THEN on the right side where my camgears are there are wires ran to a very small looking sensor that mounts directly behind my intake camgear. I am going to go to advanced auto and ask for a cam posistion sensor and see if it looks like what I need. Thanks for the help everybody.
Kinda wierd from all this I've learnt that the different year DSMs have alot more differences in them then I thought.
95 GSX 5 speed
Built head
SAFC
Greddy Type S BOV
My Car Domain
