Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 01-08-2007, 03:36 PM
1993cherokee 1993cherokee is offline
Question Heater problem
I just bought a 1993 jeep cherokee a few weeks ago and the heat worked fine but then after about a week it would only work every once in a while. Now it keeps telling me there is and error and it only blows out cold air. Is it the thermostat????? I need it fixed soon its getting kind of cold .
Old 01-08-2007, 05:15 PM
89ltd 89ltd is offline
Re: Heater problem
do you have a water temp. gauge on the dash? It would only be the thermastat if the engine is not getting up to temp. Try holding on to both the heater hoses where they go into the firewall when it is up to temp. , are they both warm?
Old 01-08-2007, 07:42 PM
AlohaBra's Avatar
AlohaBra AlohaBra is offline
Re: Heater problem
Is that a Grand Cherokee?
Old 01-09-2007, 12:49 PM
Question Re: Heater problem
Where are the heater hoses located do I have to open the hood or can I get to them from inside the truck.....??? I don't know very much about jeeps. It gets up to temp pretty quickly and when it was working the heat came out great. What could any other possibilitys be besides the thermostat?
Old 01-09-2007, 01:13 PM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
Re: Heater problem
Open the hood and you'll see something like this:
See the silver tubes that stick out just in front of the long black valve cover? The heater hoses will be attached there, and run together to your left when viewed from the front of the vehicle - passenger side - of the valve cover, then turn and go to the firewall.
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
Old 01-09-2007, 01:14 PM
AlohaBra's Avatar
Re: Heater problem
*The heater hoses are all under the hood.
*You mentioned error message, where is that displayed? (That is why I asked if it was a Grand, which has a different heat/climate control system.)
Old 01-10-2007, 03:34 PM
Re: Heater problem
Its a grand cherokee and its all digital and on the heat control panel you can select the exact heat degree but when I start it up about 30 seconds or so after it says ER. But I'll take a look under the hood and see what I find.
Old 01-10-2007, 03:49 PM
AlohaBra's Avatar
Cool Re: Heater problem
That is what I thought....there is actually a Grand Cherokee fourm...if you don't mind, I am going to move your post over there and maybe someone can help you identify your problem better.
