Go Back   Automotive Forums Car Chat > Buick > Century
Old 01-10-2007, 09:24 AM
chuck0 chuck0 is offline
Question '95 Century Speedometer
The speedometer & odometer have stopped functioning except occassionally the speedometer needle will register the speed. After reading similar problems on this site I believe it is probably the VS Sensor or its connections.
My question is: where is the VS Sensor located and is it tricky to remove ? Is it possible that only the connections or wires are corroded if it's located in an abusive environment. Thanks in advance for your advice.
Old 01-10-2007, 09:55 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: '95 Century Speedometer
The VSS is a possibility. On a 4T60E autotransaxle it is located on the right side (passenger) of the transaxle housing extension where the axle shaft connects. You will see the wiring harness and it is in an abusive environment.
Timeslip 08/12/06
AF Community Guidelines
Old 09-30-2009, 09:43 PM
Smile Re: '95 Century Speedometer
BN....thanks for the info.
