Go Back   Automotive Forums Car Chat > Pontiac > Sunbird/J2000/2000 Sunbird
Old 01-09-2007, 11:20 PM
Alejandro2007 Alejandro2007 is offline
Cooling system
I have a Sunbird 93 with a lot of mileage. My problem is that the car continue getting hot. I replace in the pass months:the water pump, the radiator, the fan motor and fix a leakege, but the car continue getting hot. I don't know what else can I do.
Old 01-11-2007, 01:31 PM
89Sunbird 89Sunbird is offline
Re: Cooling system
Replace the thermostat. Make sure the cooling fan is turning on. Check the hoses for any crimps or blockages...
Old 01-11-2007, 05:21 PM
Re: Cooling system
I have checked all. I saw in another web site that it could be the head gasket.
Old 01-11-2007, 05:37 PM
Re: Cooling system
Not likely. You would know it if it were your headgasket. When mine went out, the car ran like garbage, spewed white smoke out of the engine bay and the vents, and stunk to high heaven...
Old 01-19-2007, 01:37 PM
|WYG|SS |WYG|SS is offline
Re: Cooling system
try getting cooling system flushed caused u could have a clog someplace in the engine.
Old 01-25-2007, 01:16 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: Cooling system
What engine do you have? Are you losing coolant? How long does it take before the guage indicates it's running hot? A little more info please.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 02-09-2007, 07:40 AM
Re: Cooling system
My engine is 2.0 liters and 4 cylinders. Yes I'm losing a little of coolant. I start the engine and run for a while and no problem. The problem start when I stop in a red light and when I turn off the car and start again.
Old 02-15-2007, 12:49 PM
Matts3100 Matts3100 is offline
Send a message via AIM to Matts3100
Re: Cooling system
Sounds like a head gasket, just not internal (white smoke). Being the 2.0L it is very possible. Have a garage pressurize your coolant system and check where your coolant leak is coming from, i.e. head gasket
Old 03-02-2007, 12:27 PM
windmill68 windmill68 is offline
Re: Cooling system
I had same problem with my 88 Sunbird 2L OHC. It was head gasket.
