Old 01-09-2007, 11:45 PM
tdeome76 tdeome76 is offline
Alternator replaced and now car won't start
A week ago the voltage light came on when I turned on the overhead light while the car was running. I stopped the car for a couple hours and it started right up, but for the next fifteen minutes of the drive, all the electrical components begin to drain and I had to turn everything off to have enougth power in the headlights to see. The next morning the car didn't start. I replaced the alternator and charged the battery and it still didn't start. I replaced the battery and checked the charge, still no start. When I turn the ingnition key, the fuel pump buzzes and I get one click. I have cleaned what I can of the corrosion off the battery terminals. Any suggestions?
Old 01-10-2007, 08:03 AM
KMSwigart KMSwigart is offline
Re: Alternator replaced and now car won't start
Check ground at engine. Check all pos. connections. If you can use an ohm meter. Check fuses!
Hope this helps, Kev
Old 01-10-2007, 09:53 AM
caddyman379 caddyman379 is offline
I would check the connections at the starter. If their ok, then i would remove the starter for testing. AutoZone does it for free.
Old 01-10-2007, 07:48 PM
auto trainy auto trainy is offline
I would start by seeing if the battery is fully charged and not charged with just the alternator,then I woul double check the + battery cables(2)for internal corrosion (a very common problem),and then go after the starter,Good Luck.
